Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.6L V8 Specific General Discussion > 4.6L V8 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-20-2008, 09:07 AM   #61
RetroGT2006
RetroGT2006's Avatar
Vehicle: 2006 Ford Mustang GT
Send a message via AIM to RetroGT2006
I know my 2006 GT was woken up with that SCT flash, i had Evolution Performance do the tune- but man! Shift points are great, shifts nice and firm(when it was stock at WOT you couldnt tell it was changing gears it was soo smooth).. my car can chirp from 1-2 and 2-3.. in an auto.. and form a dig, light um up till redline in 2nd.. pretty impressive for a stock gt with intake/ axelbacks and tune..
__________________
2006 Windveil Blue Mustang GT
Slightly Modded =)
RetroGT2006 is offline   Reply With Quote
Old 12-08-2008, 10:40 PM   #62
g_coop
Just bought a gt and learned how to drive a manual the same day. Any beginner tricks I can do to get more comfortable with the car. Did a burn out once when I got stuck on a hill (it at least looked kick az)but nothin beyond that.
g_coop is offline   Reply With Quote
Old 12-08-2008, 11:13 PM   #63
07musclemustang
2007 Ford Mustang
07musclemustang's Avatar
Vehicle: 07 Mustang GT Rag Top
always try to match RPM when you shift.... let the motor slow down before letting out the clutch on the upshift and popping the throotle on the downshift. also dont try to powershift this trans... you'll blow it up in no time
__________________
07 GT Rag Premium, Black on Black
GT 500 Front End, Rear Spoiler Delete,
FRPP Hood Pins, Functional Hood Scoop,
PIAA 510 4300k Fogs, 4300k HID DRL Delete,
Steeda 90mm Intake and Tube, Steeda UDP,
BMR Combo LCA, UMI Poly UCA, BMR FSB Delete,
SCT Xcal 3, FRPP CMDP, Innovate Wide 02
PRO 5.0 Shifter, Custom T and Handle
Pypes Mid Muffs, FRPP X pipe
FRPP 4.10s and True Track
13.2 @ 109 at 2400ft above sea level
12.8 @ 111 DA corrected
07musclemustang is offline   Reply With Quote
Old 01-22-2009, 09:11 PM   #64
chuck biscuits
chuck biscuits's Avatar
Vehicle: 2008 Ford Mustang GT Premium
Question
Quote:
Originally Posted by lowrider02 View Post
Looking for some help on my 2007 GT 5-speed with 3.13 stock gears. When shifting, the RPMs race up a bit in between gears when the clutch pedal is pressed and foot off the gas. Themore I accelerate, the more the RPMs float up in between gears. Is this common? The car only has 4800 miles on it and the dealer doesn't know how to address it since they said the computer is controlling this.Everything checks out on their analyzer. This doesn't seem to occur when downshifting.
Another thing I noticed is when in 5th gear at approximayely 70 mph and 1800-1900 RPM, there's a slight droning sound. The sound quickly goes away when I hit 2000 RPM and doesn't occur in 5th gear prior to 1800 RPM. Are these common characteristics of the car?
Need help from someone with experience on this issue or if this is normal. Any comments are appreciated.
My 08 does the very same thing between shifts. Don't know if that's normal or not.
__________________
2008 Vista Blue Mustang GT Premium
chuck biscuits is offline   Reply With Quote
Old 01-22-2009, 09:28 PM   #65
07musclemustang
2007 Ford Mustang
there is drone in the motor that is excentuated by most aftermarket exhausts. at 1800-2k is where it is most prelevent. If you hate drone get a mid muff system and it will (almost) disapear.
__________________
Old 02-22-2009, 11:17 AM   #66
ezking
1997 Ford Mustang
ezking's Avatar
Vehicle: 1997 Mustang GT
The optimum rpm range for a gt is 2100-2400 rpms I believe. That drone is ur car lugging. Don't drive it like a sbc.
When u hit certain lvls of torque that noise goes away, but that's an indicator that u need to down shift or speed up.
Edit: oops u got a 3valve, not sure if this is true for them too.
Ill l2read nxt time.
Also ur car stops making power @ 5250, so don't shift at 6k, shift at 5500 and ull get more out of it
ezking is offline   Reply With Quote
Old 06-16-2009, 10:46 AM   #67
rheat
Vehicle: 2006, Ford, Mustang GT
Does anyone know the gear ratio for a 5sp manual transmission in a 2006 mustang gt?
rheat is offline   Reply With Quote
Old 07-28-2009, 11:56 AM   #68
texasstang1962
Vehicle: 2008 ford mustang GT
Default need some back up.
ok, i have an 08 gt 3v-auto. some of the guys at work are busting my b%lls for having an automatic, but i love it, i drove a 4cyl stick- toyota p/u for 20yrs,i'm sick of shifting, i call it "clutch foot" it felt so good to have an auto, no shifting AWWWW feels so nice. And my stang " I feel, runs great" i have Vortech v3 s-trim, dyno sheet reads, 439hp -stock h-pipe. Is my tranny weak or something, should i have a different stahl conv installed, or what. can someone tell me that my auto trans is a good strong one for an 08, please tell me something good about my tranny, so i can print it out and show the guys @ work that my 08 automatic trans is not a weakling.
( Or,,,are they right ) ?
Any feed back will be greatly appreciated.
texasstang1962 is offline   Reply With Quote
Old 07-28-2009, 01:19 PM   #69
Riptide
Riptide's Avatar
Vehicle: 2006 GT
If it helps you feel better the automatic is more consistent and much easier to use at a drag strip than the manual. Most people will tell you that the auto is going to win you more races, even on the street.
__________________
2006 GT, Manual
JLT2 w/91 Tune
FRPP 4.10, Steeda LCA
MAC Boomtubes
Goodyear 255/45/18, 285/40/18
Riptide is offline   Reply With Quote
Old 07-29-2009, 02:37 AM   #70
texasstang1962
That does make me feel better. I do need to concentrait on a higher stahl converter though.
2008, 5r55s, autotech, converter, feel, forum, kit, mustang, reprogramming, roush, sale, slipping, stall, trans, transgo, uae
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
