Transmissions: Manual & Auto Tech - Page 9 - MustangForums.com
Sponsored by:
Sponsored by:
Old 10-23-2011, 10:25 AM   #81
Tim2005
go to the website mustang parts salvage they will have everything for you they can at least lead you in the right direction
Tim2005 is offline   Reply With Quote
Old 10-23-2011, 10:34 AM   #82
Tim2005
Quote:
Originally Posted by hammer1981 View Post
what is needed to swap a auto to manual for a 2006 mustang gt
google mustang parts salvage i think the website is mps.com? not 100% sure google it youll find it...they will have everything you need to convert a auto to man
Old 02-20-2012, 04:17 PM   #83
manuel86it
i am confused too about the right fluid..
here in Italy it's quite easy to have Royal Purple products (plus we build cnc machinery and RP also supply oil for them), but for our TR3650 manual transmission (mine is a 2010 gt) it seems i can use both the synchromax or a 75W-90 max gear from Royal Purple.
i don't get the difference between these two product, except from that in technical sheets synchromax is more correct for automatic transmission, but it looks like many of you use this in manual transmission. so what's your advice? i want to gain smoothness in changing gears, so i'm looking for changing the fluid.
thanks!
manuel86it is offline   Reply With Quote
Old 10-17-2012, 01:35 PM   #84
scottw2010
I just changed my manual tranny fluid today. Car only has 22K on it and the old fluid pretty much looked new. Changed it with Mobile 1 ATF. I put in 3 and some change to try and make 3.2 quarts.
My question is how do I check to make sure I have enough fluid in it and what are the symptoms of low fluid level in a manual?
scottw2010 is offline   Reply With Quote
Old 10-21-2012, 05:02 PM   #85
Junior Lomeli
what the best trassionmisson to get on autom mustang gt ?
how much would rebulid cost me ?
AND MY CAR HAS ONLY 47,000 MILES AND MY 2AND3 SLIP ?
Junior Lomeli is offline   Reply With Quote
Old 11-27-2012, 08:21 PM   #86
Bradgreenway
Bradgreenway's Avatar
Does anyone know where I can find information on automatic to manual s197 transmission swaps?
Bradgreenway is offline   Reply With Quote
Old 12-05-2012, 10:34 PM   #87
wannaspeed
Hey guys, pulled the engine out of my 08 GT for some upgrades. While its removed im going to change the clutch, but i have a question regarding the slave. Do i need to remove the tranny? It seems pretty accessable as it sits so it seems that i can just cap the line, pull the slave, bleed the new slave, and install. My question is will it be this simple and will i be able to bleed the clutch with the engine removed. Like pump the pedal and all that? May seem like a stupid question but i was told not to depress the clutch while the engine was removed. Any advice will be greatly appreciated!! Thanks
wannaspeed is offline   Reply With Quote
Old 01-13-2016, 01:18 PM   #88
doctorpimp
doctorpimp's Avatar
doctorpimp is offline   Reply With Quote
Old 02-14-2016, 11:20 AM   #89
BrianK
BrianK's Avatar
I have an 07 GT auto. I installed my own dipstick. Google 'Ratstang' and look at his web site. I did something very similar and I like having it.
http://www.ratstangrestoration.com/5r55s-dipstick.htm
On his web site he also says that the Bands can be adjusted. Has anyone done that to their auto? Is it worth it to do that? My tranny is working fine, but if I can adjust something that should be done occasionally to compensate for wear, I'll do it.
BrianK is offline   Reply With Quote
Old 02-23-2017, 04:08 PM   #90
ZillaF
Default 07 GT, 5 speed Hurst short throw, 410 gears
Hello everyone, I hope this is the proper forum for this question. I've been driving manual trans cars for over 30 years and always thought I was good at it until now. I thought with the short throw shifter and 410 gears I'd be hanging through the gears but it's not happening. I don't know if it's the hydrologic clutch or what but it seems I have to have the clutch to the floor to shift. This isn't a problem during normal driving but if I'm trying to get on it is just embarrassing. Having trouble running through the gears when under power. Is it getting to know this clutch, operator error or common problem? Thanks Z
ZillaF is offline   Reply With Quote
New guy in AZ. First Mustang, First Manual, First car. BeatnikFink New Member Area 6 10-01-2015 08:00 PM
Monte Carlo bar w/ AC fastbackford351 Classic Mustangs (Tech) 3 10-01-2015 12:24 PM
4r70w torque converter q's guitarman376 4.6L (1996-2004 Modular) Mustang 0 09-30-2015 05:54 PM
Need to rebuild the automatic transmission 1996 GT wraith777 General Tech 1 09-28-2015 10:49 AM
swapping trannys 2poor4u2 V6 (1994-2004) Mustangs 1 09-26-2015 11:08 AM
2008, 5r55s, autotech, converter, feel, forum, kit, mustang, reprogramming, roush, sale, slipping, stall, trans, transgo, uae
