Can a bad torque converter/transmission bog down the engine enough at speed to kill the engine? I know it can kill the engine when you stop but haven't heard of this happening when up to speed.
The car runs fine at low speeds (0-45 mph) and will go through 1st to 3rd gear with no problems, but when you get on it and it should be shifting to 4th gear; the RPM's go up for a few seconds then plumet down and the engine quits. Restarts fine. If you slowly bring up the speed it works most of the time and you can cruise 70-80 mph with no problem.
Been havingthis problem for over 2 years: See original forum post here: http://www.mustangforums.com/m_13150...tm.htm#1315019
and still haven't got it fixed. Had three mechanics look it over and all came up with nothing.
Thanks for any help.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
Have you pulled codes yet? Its sounding like something other than the transmission because your saying it eventually gets there, but if it was the transmission you wouldn't.
Try doing a good look around the engine and transmission to see if anything is missing or broken
__________________
1988 Mustang LX
Ex 2.3 N/A car, was a 2.3 turbo, now getting a complete forged & stroked 408W, shooting for a TT setup
1992 GMC Sonoma 4x4
185,000km's|4.3 auto|current DD getting 24mpg
1991 Mazda MX6 DX
299,000 km's (over 186K miles)| TOTALED!
The only code we've ever been able to getwas P211 (PIP signal erratic) other then that, nothing and the check engine light has never come on. Have done visual checks and haven't seen anything.
That is an ignition problem. It's the pickup for the signal to fire the engine.
Buy another distributer and put it in and see if anything changes
__________________
1988 Mustang LX
1992 GMC Sonoma 4x4
1991 Mazda MX6 DX
Finally SLEEPER SLIPPED!
DIS SLEEPER!!!!!!!!!
no distributor on a 93! [8D]
check the 2 dis boxes.
and don't give a smartass reply either
__________________
I'll kick your sorry arses so hard you'll kiss the moons.
