Turn signal trouble 2.3l LX Convertible
My turn signals just quit working. I have checked the fuses, the relay, and have replaced the switch on the column. Neither the indicators in the cab nor blinker sounds are working. When I turn on the hazards only the right indicator light blinks.
What else could it be? Help is greatly appreciated.
Rick, I may have found our problem. Under the dash and behind the stereo is a small relay for the blinkers. It is a Wagner blinker relay (part number 224 12V). It is what you actually hear switching the blinkers on and off as it actuates. It is about 1 1/4 inches around and has two males plug in spades coming out of it. It looks just like the relay in the fuze box but a little smaller. I will try and change mine out tomorrow sometime and see if it is working. I will reply back asap to let you know.
