spark problem help
spark problem help
i just got a 1993 mustang , not much of a ford guy but the price was right and they get good mpg. well it is a 1993 2.3 with the 8 plugs. well i changed the plugs . on start up for about 1 min it runs with out a miss then the miss comes. so i check the firing order it is right. i started pulling wires off the coil. and they where not sparking. so i whend around to all of them sum where sparking sum where not on all 8 then i got done pulling 1 off and puting 1 back on on all 8. then i when back around and did it again and sum where sparking that where not the first time and other that where sparking the first time i check where not now. i did a running engine code check befor i changed the plugs and got a 998 , 224 chacked the code and i did not under stand what the book meant? please help me out
998 - don;t worry unless transmission isn't shifting right.
224 - coil failure
224 means one or both of your coils are failing/failed.
Take them to your local parts store and get them to test both for you.
224 - coil failure
the kid i got it from said the coil where new i will have them tested thow to make sure. could it be the Ignition Control Module??? that is what i thought it was but my auto parts shop cant test that kind of ford Ignition Control Module
Golfsito
10-06-2015 11:02 AM
