New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Ford Mustang Tech > 4 Cylinder NA and Turbo > 4 Cylinder General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-24-2008, 08:57 AM   #11
sleeper_inc
1988 FORD Mustang
sleeper_inc's Avatar
Vehicle: 1988, Mustang, LX
No, a 351 will make to much power and snap it like a twig. I thought you were talking about the 2.3, but anyways for a V8 thats going to be making power I would adcise you to look at a TKO or a built AOD/C4.
The T5 will hold but if you beat it enough it will break
__________________
1988 Mustang LX
Ex 2.3 N/A car, was a 2.3 turbo, now getting a complete forged & stroked 408W, shooting for a TT setup
1992 GMC Sonoma 4x4
185,000km's|4.3 auto|current DD getting 24mpg
1991 Mazda MX6 DX
299,000 km's (over 186K miles)| TOTALED!
sleeper_inc is offline   Reply With Quote
Old 11-24-2008, 09:04 PM   #12
marioso28
1993 Ford Mustang
Vehicle: 1993 Ford Mustang GT 5.0
TKO or AODC4 eh? Are these stock tranny's?
__________________
1988 Ford Mustang LX
marioso28 is offline   Reply With Quote
Old 11-24-2008, 10:30 PM   #13
Boost Gobbler
Boost Gobbler's Avatar
indeed, im about ready for a new one but mine had about 140K miles on it before i got to it.
do you mean a modded 351's power vs a stock 2.3 or 2.3t?
__________________
I stole it from grandma..
best time on the slip so far, 13.2 at 106 soon to rise. check out my gotstang page for more info.
Boost Gobbler is offline   Reply With Quote
Old 11-24-2008, 10:35 PM   #14
sleeper_inc
1988 FORD Mustang
the 351W's power band will snap the 2.3 T5 like a twig. The 2.3T has a "lower" band that the 351 at first but climbs steady
__________________
1988 Mustang LX
1992 GMC Sonoma 4x4
1991 Mazda MX6 DX
Old 11-25-2008, 10:49 PM   #15
Boost Gobbler
Quote:
so your saying for example we have a 2.3t with 300hp ant tq and a 351 with the same power that the 351 would destroy a t5 in a drag racing senario because it has more low end torque? i dont know about that. even though it may have a bit more grunt on the low end, in most case's a forced induction engine especialy a turbo charged one will reach its max torque before a n/a engine will. i dont see why i t5 couldnt be used on a 351 unless its something like a 400 hp/400tq 351, but then i wouldnt put that same t5 on a 2.3t with the same power ether.
__________________
Old 11-26-2008, 04:55 AM   #16
86GT 93LX
86GT 93LX's Avatar
Quote:
Originally Posted by marioso28 View Post
Have no problem changing the clutch. Need to do that anyway. But can the T5 hold a 300 plus hp? What other Mustangs/Fords is it on?
none of the stock t5s are rated at 300hp except the 93 cobra spec t5 and yes they can hold 300 but not for long.a G FORCE rebuild is said to hold 600ft/lbs of torque and as much hp if not more. the t5 in the 5.0 circles is referred to as the temporary 5. it is the weakest link in the 5.0 drive train and a stock 5.0 doesn't make 300hp and they still don't always last. but for sure they are the best choice out there unless you like a c4 witch can hold a lot of power if built correctly and its supposed to be the cheapest to build, alota drag racers build them
but you would need a pinto bell housing. t5 is your cheapest best most reilable bet. u can get one from the junk yard and beat the crap out of it for a while before you have any problems, then decided if you wanna spend the money on a geforce rebuild which goes to straight cut gears. good luck
__________________
86gt maf,bbk underdrives,taurus 3g alt, contour dual e fan,crane cams ignition/coil,mac equal length shortys, off road h pipe, flows dumped. 5 lug and aluminum drive shaft next.
86 cherokee 6" lift 4.10s
89 cameo el
86GT 93LX is offline   Reply With Quote
Old 11-26-2008, 08:50 AM   #17
sleeper_inc
1988 FORD Mustang
I'm just speaking from what I've seen. I've seen lots of 2.3T5s on 5.0's and 351's run just fine, but I've also see them almost explode on a hard launch.
__________________
1988 Mustang LX
1992 GMC Sonoma 4x4
1991 Mazda MX6 DX
Old 11-26-2008, 10:33 PM   #18
marioso28
1993 Ford Mustang
hmm. this is a lot to think about. Once I put in a new engine I wont always drive or dog it. So maybe a new T5 will work? That way I can dog it every now and then and still not worry about my investment blowing up???
__________________
Old 11-26-2008, 11:55 PM   #19
sleeper_inc
1988 FORD Mustang
If your going to buy a new one for an extra $300-$500 you can get a TKO 6 speed
__________________
1988 Mustang LX
1992 GMC Sonoma 4x4
1991 Mazda MX6 DX
Old 12-02-2008, 03:24 PM   #20
marioso28
1993 Ford Mustang
TKO 6 speed? awesome. I guess that is the new goal on the list. anyone have a link where I can get one? or the cars I can get one from?
__________________
a4ld, pdf, rebuild
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
