Go Back   MustangForums.com > Ford Mustang Tech > 4 Cylinder NA and Turbo > 4 Cylinder General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 01-22-2009, 10:56 PM   #1
al_ngl
1993 Ford Mustang
Vehicle: 1993 Mustang LX 2.3
Send a message via Yahoo to al_ngl
Default Engine Cleaning
I don't think there has been a thread on this in the 2.3 section, so I'll post a sort of basic how-to. I've been wanting to clean my engine for a long time mostly because of the grime that builds up on the valve cover. I did a little research and found that a lot of auto enthusiasts use a Citric acid orange cleaner with good results as a de-greaser. The advantages over an automotive de-greaser are the price, and the safety for your painted, plastic, and rubber parts under the hood. I have been told that "Simple Green" is even better than a Citrus based cleaner, and doesn't require any scrubbing.
The first thing you want to do is cover up your sensitive electronics and other places you don't want water: battery, air cleaner and MAF, and distributor/coil packs. I just used Wal*Mart bags, which were big enough and didn't really need held down very much. Everything else should be able to withstand a little water.
**Disclaimer: I should mention at this point that oil and any other engine fluids are harmful to the environment and you should take all precautions to catch drippings from the car and dispose of them properly.**
Then, spray your de-greaser liberally on your COOL engine. With the citrus cleaner you can scrub at some spots, wipe some right away, and just soak hard/difficult spots to be scrubbed or rinsed off later. Don't let the de-greaser dry. Rinse with a hose, being careful not to use a ton of pressure. I'm told that if you use simple green, you need not scrub at anything. Just spray, wait for it to lift the grease, and rinse with water. Perfectionists will seek out hard spots, but I'm just going over a basic wash. You may want to use a toothbrush for hard to reach crevices, such as around the valve cover, and near the spark plugs.
After rinsing off the engine, remove the water protection from your engine, and start the engine for a few minutes to cook off any standing water on the engine. Here's mine, I only spent half an hour, but it still looks much better than before.
Any questions, comments, or tips please reply.
__________________
"The battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol, but the clock is correct!"- James May
al_ngl is offline   Reply With Quote
Old 01-23-2009, 11:33 AM   #2
sleeper_inc
1988 FORD Mustang
sleeper_inc's Avatar
Vehicle: 1988, Mustang, LX
I go to the car wash and do it there... Engine cleaner function FTMFW!
__________________
1988 Mustang LX
Ex 2.3 N/A car, was a 2.3 turbo, now getting a complete forged & stroked 408W, shooting for a TT setup
1992 GMC Sonoma 4x4
185,000km's|4.3 auto|current DD getting 24mpg
1991 Mazda MX6 DX
299,000 km's (over 186K miles)| TOTALED!
sleeper_inc is offline   Reply With Quote
Old 01-24-2009, 02:14 AM   #3
F1aReD
Send a message via AIM to F1aReD
I always wanted to do this with my old stang, but I was too afraid of breaking something and I didnt even know what to use. I'm gonna do this if/when I get a new one. Thanks for the tips
__________________
1992 Mustang LX Convertible 2.3-Totalled
1995 Dodge Neon-5 speed-Girlfriends "winter beater"
1998 Nissan Sentra-Project
F1aReD is offline   Reply With Quote
Old 01-28-2009, 07:31 AM   #4
TBird232ci
Send a message via AIM to TBird232ci
I can give you guys some more tips here. I always have the cleanest engine compartments compared to my friends cars.
Simple green does work wonders, but it will chalk up your aluminum. The citric acid cleaners don't work as well as Simple Green, but it's a little less harmful on your aluminum. Another option is to use the citric acid cleaners, and then a larger amount of Dawn dish washing detergent in a bucket with warm water and a brush and/or rag. Dawn works great.
Don't be afraid to use pressure. Be easy around your vacuum lines and main harness at the firewall, but everything else, give it hell.
If you have some really nasty, thick and built up grease, get some rags and Brakeclean, the stuff in a red can. Use some rubber gloves if your hands can't handle the chemicals. Soak the rag in Brakeclean and scrub down the offending area. Once it's broken up, spray that particular area down with the brakecleaner, then follow with the citric acid cleaner, which will help reduce the harm the brakeclean can cause.
Once you get it clean enough for your liking, get a can of tire foam and shine stuff. Let the engine bay dry completely, and with it cool, spray down the entire engine compartment and walk away. In about a half hour, come out and use a clean rag to wipe away the excess.
This is an old picture, but it shows the results of the cleaning method I use.
__________________
TBird232ci is offline   Reply With Quote
Old 01-28-2009, 02:05 PM   #5
al_ngl
1993 Ford Mustang
Wow, that is very clean! If you use simple green, can you clean up the aluminum with dish soap to get the chalking off? I did notice that the citrus cleaner didn't clean the aluminum at all.
__________________
Old 01-28-2009, 03:21 PM   #6
TBird232ci
The chalking is the aluminum actually corroding slightly. The tire shine helps remove and mask over some of the corrosion.
I'm not sure if dish detergent would work with removing the chalking, I never tried it.
__________________
Old 01-29-2009, 12:46 AM   #7
F1aReD
That looks awesome! I never really thought about using the tire shine
__________________
Old 02-01-2009, 11:32 PM   #8
924banger
1992 Ford Mustang
Lexol rubber cleaner works really good for the plastics under there also. It doesn't leave it shiny like tire shine but it cleans under the surface of the material and will last for about a month, longer if you don't drive 600 miles a week like I do. I also hydrates rubber.
__________________
Red 92 LX mustang 4cyl
1992 Bronco 5.8L
2003 Cavalier 2.2L Ecotec
1993 Lightning #1579...Died 12/21/06
924banger is offline   Reply With Quote
acid, citric, clean, cleaner, cleaning, cylinder, dish, engine, green, mustang, simple, soap, worcestershire
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
