Go Back   MustangForums.com > Ford Mustang Tech > 4 Cylinder NA and Turbo > 4 Cylinder General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 03-16-2009, 12:39 PM   #1
stangmanSVO
stangmanSVO's Avatar
Vehicle: 1985 SVO and 1990 "342" 7up
Default need some input
ok so i have a 1985 SVO which is getting quite a bit of mods and i dont think that the 7.5 rearend will hold up. i have a 5 lug 8.8 and was wondering how much modification / fabrication will need to be done. i dont want to pull the 7.5 without the materials i need for the 8.8. will the brakes bolt right up? any brake line fab? and will the tires stick out any further? im pretty sure they will just not sure how much. thanks for any help.
stangmanSVO is offline   Reply With Quote
Old 03-16-2009, 01:46 PM   #2
fast65
1984 Ford Mustang
My Garage
fast65's Avatar
Vehicle: 1965 Mustang GT, 1984 Mustang SVO
Send a message via AIM to fast65 Send a message via Yahoo to fast65
That depends on what the 8.8 came out of. If it came out of a Turbo Coupe I think it's a direct replacement, but if it came out of anything else I'm pretty sure you need to do some modification, not sure what that is though. Sorry I couldn't be of more help.
__________________
'65 Mustang GT-stroker 347 w/Toploader 4-speed
'84 SVO-2.3T at 17 psi
fast65 is offline   Reply With Quote
Old 03-16-2009, 01:59 PM   #3
stangmanSVO
im pretty sure its out of a 95 or 96 gt
Old 03-16-2009, 02:05 PM   #4
stangmanSVO
i just dont know if the brake lines will bolt up to the 8.8. idk why they wouldn't. i was hoping for a simple swap. shocks, brakes, lines and all but i dont think that will happen. is there ayway to make the 7.5 handle 450hp? stronger axels/differential? if so thats what i would rather do.
Old 03-29-2009, 03:04 AM   #5
302_fd
Vehicle: 93 notch
turbocoupe rear is supposed to be a little wider than yours. I posted link in another post with this info page you might want to look at it too. It has links for rear end upgrades.
http://www.veryuseful.com/mustang/tech/engine/
Easiest would be to use 8.8 axle from 5.0, better options available, direct bolt in.
302_fd is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
