Go Back   MustangForums.com > Ford Mustang Tech > 4 Cylinder NA and Turbo > 4 Cylinder General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 03-22-2009, 09:28 AM   #1
SMOKEATER52
Vehicle: 92 Ford Mustang Lx 2.3L
Exclamation Turbo or not Turbo
Hey everyone
I am new to the site and I would like some input on turbo kits for the 2.3
I have a 92 convertible, runs good, about 125000 on the motor and I have no idea what trans is in it. I have been thinking about putting a turbo in the car, but I am not sure if it would be too much strain on the motor and trans. I am also open to suggestions on other ways to get a little more out of it without a turbo.
SMOKEATER52 is offline   Reply With Quote
Old 03-22-2009, 10:00 AM   #2
al_ngl
1993 Ford Mustang
Vehicle: 1993 Mustang LX 2.3
Send a message via Yahoo to al_ngl
You generally don't want to add a turbo to an N/A engine, as you would have to build up the internals and spend way more than swapping in a turbo engine. You can pick up a turbo 2.3 engine at almost any junk yard, or search craigslist. They will be cheaper than any turbo kit. When you find a good engine, just come on back and someone will guide you through the swap. Is your tranny auto or manual? Auto is A4LD, and manual is T5 unless the previous owner swapped trannies.
Now about non-turbo power, it's going to cost a lot more money per horsepower. You can put in a bigger cam, a ranger exhaust header, a cold air intake, and maybe some porting and polishing. Doing all of that will cost a lot, but you will get a lot of power compared to the 105 that you have now.
__________________
"The battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol, but the clock is correct!"- James May
al_ngl is offline   Reply With Quote
Old 03-22-2009, 04:51 PM   #3
SMOKEATER52
Coool, thanks for the info. It is an automatic trans by the way. I just don't have alot of money to put into it right now.
Old 03-22-2009, 08:13 PM   #4
al_ngl
1993 Ford Mustang
Well you are in the same boat with a lot of us then. For free HP, you can take the silencer out of the air tube between the MAF and the throttle body. You could replace this with a piece of 3" pvc pipe also. Do you have emissions tests in Florida? If not, you can also make an egr block for pretty cheap with a piece of scrap metal. Then you can go to a junk yard and pull a ranger header out of a 94-95 I think, and install that. Those are the cheapest mods you can do, and you could probably do all three for under $30.
__________________
Old 03-29-2009, 02:39 AM   #5
302_fd
Vehicle: 93 notch
Look for 87,88 thunderturd turbocoupes. They have best cpus, vams. Merkur x4rti same year. If no luck, start colecting pieces little by little, as time/money allow. Depending on your mechanical ability would dictate best method of install, meaning keeping your 8 plug head/block, or swapping 4 plug/dizzy motor. Each one has its pros and cons. Ive built alot of these motors, and they can make a huge amount of power.
302_fd is offline   Reply With Quote
Old 03-29-2009, 03:07 AM   #6
302_fd
Vehicle: 93 notch
I also have all these parts, if you need them
Old 03-29-2009, 09:21 PM   #7
sleeper_inc
1988 FORD Mustang
sleeper_inc's Avatar
Vehicle: 1988, Mustang, LX
Quote:
Not true, all XR4Ti's got small VAM
__________________
1988 Mustang LX
Ex 2.3 N/A car, was a 2.3 turbo, now getting a complete forged & stroked 408W, shooting for a TT setup
1992 GMC Sonoma 4x4
185,000km's|4.3 auto|current DD getting 24mpg
1991 Mazda MX6 DX
299,000 km's (over 186K miles)| TOTALED!
sleeper_inc is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
