New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Ford Mustang Tech > 4 Cylinder NA and Turbo > 4 Cylinder General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 03-23-2009, 03:28 PM   #1
Al73mustang
Al73mustang's Avatar
Vehicle: Ford 1990 Mustang
Default Where can I buy transmission lines
I was replacing the radiator in my 4cyl coupe and when I was removing the transmission line that goes to the radiator it started to twist. So I tried braking it loose but had no luck. So now I need to find some replacement lines or some how fix what I have. I ended up braking the line right at the fitting. Anyone knows where I can buy a new line?
Al73mustang is offline   Reply With Quote
Old 03-23-2009, 09:29 PM   #2
sleeper_inc
1988 FORD Mustang
sleeper_inc's Avatar
Vehicle: 1988, Mustang, LX
A local JY... Sorry, but thats your best bet for an item and price. I would just run some transmission tubing (rubber) to the fitting and the tubing
__________________
1988 Mustang LX
Ex 2.3 N/A car, was a 2.3 turbo, now getting a complete forged & stroked 408W, shooting for a TT setup
1992 GMC Sonoma 4x4
185,000km's|4.3 auto|current DD getting 24mpg
1991 Mazda MX6 DX
299,000 km's (over 186K miles)| TOTALED!
sleeper_inc is offline   Reply With Quote
Old 03-24-2009, 03:46 PM   #3
Al73mustang
Thanks sleeper but that is what I was trying to avoid so I came up with my own little solution. I bought a straight steel line for brakes with the same diameter and flange size. I had to re-use the nut that goes to the radiator because the one it came with was too short. So I i drilled out the old tube in the nut and once I cut the new line to the size that I needed I put the old nut on it and made a couple of 90* bends. Then I used the rubber hose and clamps to mate the new tubing with the old and it worked like a charm! Ill post some pics as soon as it stops raining.
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
