New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Ford Mustang Tech > 4 Cylinder NA and Turbo > 4 Cylinder General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 05-11-2009, 10:42 PM   #1
dual_mustangs
Vehicle: 89 ford mustang
Default 2.3 pcv & vacuum help
i have an 87 2.3 mustang, and it doesnt stay ideling, ive been told its either the vacuum lines and/or pcv valve. i have no idea where to start looking for both, if someone could point me in the right direction, thanks.
dual_mustangs is offline   Reply With Quote
Old 05-11-2009, 10:58 PM   #2
dreamer1uk
Vehicle: 1993 Mustang Convertible 2.3 N/A
Send a message via Yahoo to dreamer1uk
Hi,
What do you mean by "it doesnt stay idleing"?. Does it idle then die, idle really high or idle really low?
I would start off by looking at the IACV (Idle Air Control Valve) located on the Throttle Body. Make sure its not all gummed up with carbon. Its held on by 2 bolts.
As for the PCV Valve, that is located below the lower Intake Manifold near the rear of the engine on my 93. It may be different on an older Mustang.
For the Vacuum Lines, you could start by checking all of them for damage, such as cracks and dry rot. You could even spray some starter fluid on suspect vacuum lines and see if the idle increases.
Hope this helps.
__________________
1993 2.3 Mustang Convertible
dreamer1uk is offline   Reply With Quote
Old 05-11-2009, 11:15 PM   #3
dual_mustangs
hi.
it starts, idles, bout 15-20 secs later, it dies unless you give it gas. the vacuum lines, i dont even know which lines they are, or where they go. i have a haynes book, but its very vague. thanks.
Old 05-13-2009, 10:03 AM   #4
trashline
Vehicle: 1965 ford mustang
pvc valve isnt going to do it. un metered air can, which is what a huge vacuum leak would do. unless the pvc valve is unhooked, check all rubber hoses running around the motor for cracks and broken ends.
__________________
65 Mustang modded Pics of progress
My CarDomain Page
trashline is offline   Reply With Quote
2.3, 23, 50, check, ford, forum, iac, leak, location, mustang, pcv, pvc, sensor, vacuum, vacuum lines
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
