New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Ford Mustang Tech > 4 Cylinder NA and Turbo > 4 Cylinder General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 06-15-2009, 01:05 PM   #1
RAMROD7
Vehicle: 88, Ford, Mustang
Default 2.3 Hesitates when first accelerating
I have a 2.3 mustang that hesitates or runs rough when you first accelerate. This happens from a dead stop or if car is cruising at low speed and step on it. I have replaced PCV valve and was looking for any other input to problem.
RAMROD7 is offline   Reply With Quote
Old 06-17-2009, 12:01 AM   #2
dreamer1uk
Vehicle: 1993 Mustang Convertible 2.3 N/A
Send a message via Yahoo to dreamer1uk
Hi,
Is the CEL on? If so, retrieve the codes and get back to us
If not, when was the last time the basic maintenance was performed, such as plugs, wire ect? Did you try cleaning the MAF? (depending on the year).
__________________
1993 2.3 Mustang Convertible
dreamer1uk is offline   Reply With Quote
Old 06-17-2009, 10:00 AM   #3
sleeper_inc
1988 FORD Mustang
sleeper_inc's Avatar
Vehicle: 1988, Mustang, LX
Check for vacuum leaks, bad timing, tune up, bad FPR, clogged fuel filter, etc
__________________
1988 Mustang LX
Ex 2.3 N/A car, was a 2.3 turbo, now getting a complete forged & stroked 408W, shooting for a TT setup
1992 GMC Sonoma 4x4
185,000km's|4.3 auto|current DD getting 24mpg
1991 Mazda MX6 DX
299,000 km's (over 186K miles)| TOTALED!
sleeper_inc is offline   Reply With Quote
Old 06-17-2009, 11:03 AM   #4
RAMROD7
Question
New plugs, new wires, new Idle Control Valve, new fuel filter, some of the vac lines are new. Installing new EGR, if that does not correct what then?
RAMROD7
Old 06-18-2009, 12:35 AM   #5
dreamer1uk
Hi,
What year is the Mustang? and did you have the vehicle scanned for any CEL codes?
__________________
Old 06-29-2009, 09:40 PM   #6
misfitsgrrl
Vehicle: 1988, Mustang, Lx
Interesting! I was having the same problem...up until my freaking engine cut off while I was on the interstate. Turns out the timing belt broke, another belt had a crack, the rotar button split, spark plugs were bad....anyways, we replaced all of that Sunday. Now it drives better than ever before! Just get a full tune-up and check all of your belts. It's probably timing.
misfitsgrrl is offline   Reply With Quote
Old 06-30-2009, 07:43 AM   #7
RAMROD7
Cool EGR Solenoid
Thanks to all that replied. After replacing the idle control module and EGR valve things go worse. I took it in to get it checked out and found that the EGR Solenoid was stuck.
1988, 23, 46, 93, accelerates, accelerating, firing, ford, hesitates, hestitates, mustang, order, rough, running, vehicle
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
