Hi,
Everytime you turn on an electrical component, you are creating an extra electrical load for the charging system to deal with. If every single accessory is on, the vehicle will also use some of the battery voltage to help with the demand.
First of all, check your belts
You can also do a quick self test of the charging system if you have a DVOM or a Volt Meter. When the vehicle is running, hook up the DVOM to the battery and look at the voltage. The voltahe should be between 13.5 and 15.5 volts. If the voltage is too low/high, you may have a faulty voltage regulator on the alternator, or a bad connection from the PCM to the Alternator (if its too low as the alternator isnt energizing)
If you dont have a DVOM or a volt meter, most autoparts stores will do free alternator and battery testing.
If your alternator and battery both test out good, you may have some excessive resitance in the charging system wiring (bad grounds, corroded wiring ect). You can do voltage drop tests to find those symptoms out.
As for your engine idle in general, it sounds rather low. You may want to reset your idle (theres write ups and links on these forums to do that) as well as cleaning out your IACV.
When was the last time you did a good tune up?
