4 Cylinder General Discussion For non tech 4 Cylinder owner chit chat
Intermittent charging
Old 03-20-2011, 06:03 PM
android
android's Avatar
Default Intermittent charging
sometimes charge drops(below 12 VDC) off and accessory operation makes it worse and will even stop the engine. I've watched this happen while not touching anything and a voltmeter hooked up to battery! Suspect cooling fan as it then came on and and charge returned to normal. BTW for those of you that have a battery drain problem, check to make sure hood doesn't touch top posts!
android is offline
Old 07-12-2011, 04:21 PM
bl817
bl817's Avatar
my 93 would do the same thing, i opted for the 3g alternator swap, other than doin a lil bit of grinding to the alt bracket it was super easy and i dont have any charge/drain problems anymore even at night with the ac,lights,radio,cooling fan, and ac blower goin, plus car doesnt try to die on me anymore, well worth it. good luck
bl817 is offline
Old 07-13-2011, 03:37 AM
mikerp76
mikerp76's Avatar
also check your connections on the back side of the guage cluster. a bad volt meter can case chargeing issues as well.
mikerp76 is offline
bradleyb
11-27-2015 07:50 PM
svfetter
10-05-2015 11:39 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
SteelerNation82
09-16-2015 07:11 AM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: Intermittent charging
