4 Cylinder General Discussion For non tech 4 Cylinder owner chit chat
Help please!
Old 06-01-2011, 09:32 PM
4bangerstang
4bangerstang's Avatar
Default Help please!
Have a 93 Ford Mustang 4 cylinder 2.3. Washed the motor down for a car show the other week and went to start it a few hours later and it wouldnt start. Didnt hear the fuel pump kick on so put a diff fuel pump on and stilll nothing...check the saftey switch and its fine, checked the fuel pump relay and its good. Any suggestions?????
4bangerstang is offline
Old 06-02-2011, 03:08 AM
mikerp76
mikerp76's Avatar
there is a little black box on the passenger side of the engine bay that is you multifunction relay. it controls your pump a/c and a few other things as well you may have gotten water inside of it and shorted something out.
mikerp76 is offline
Old 06-02-2011, 10:28 AM
4bangerstang
That checks out fine Mike. I have no spark though and no fuel coming in. We forced some fuel in to try and get it to start, but got nothing. Maybe the computers fried.....any thoughts?
Old 06-02-2011, 01:45 PM
mikerp76
mikerp76's Avatar
check you fusible links and your connections at your pcm. the pump should come on as soon as you turn on the key. then shut off after a few seconds. aso make sure you didn't get any water into the ignition control module.
mikerp76 is offline
Old 06-02-2011, 01:59 PM
4bangerstang
Yup they all checked out to be fine. Trying a computer out of a 90 4cyl Mustang to see if it will work. Any other thoughts? I appriciate the ones u have
Old 06-02-2011, 02:12 PM
mikerp76
mikerp76's Avatar
check your connector for your crank sensor. the 90 pcm may not fit due to the connections are all wrong. atleast according to my haynes manual. i'm running out of ideas at the moment. but will try to think of anything else. i will check back on your progress later tonight as i have to get ready for work.
mikerp76 is offline
Old 06-02-2011, 06:06 PM
4bangerstang
My computer is fine now. Next step we unplugged the relays and it fired off, but then shut off right after. Checking fuse box linkages....suspecting wiring is junk somewhere
Old 06-02-2011, 06:45 PM
4bangerstang
Got the pump and everything working now....just need spark
Old 06-03-2011, 12:07 AM
mikerp76
mikerp76's Avatar
cool. have you tried to unplug and reconnect your crank sensor and you ingnition control module?
mikerp76 is offline
Old 06-03-2011, 01:07 AM
4bangerstang
ignition control yes, crank eh not yet. I put new coil packs on it when it started this mess too and tried to fix it with them. We are going to put my old ones back on tomorrow to see if it helps...but will try crank sensor too. Thanks man
