4 Cylinder General Discussion For non tech 4 Cylinder owner chit chat
Electrical problems. PLEASE HELP!
Old 12-12-2012, 10:05 PM
Londers27
Londers27's Avatar
Default Electrical problems. PLEASE HELP!
Yesterday I bought a 1988 2.3 mustang. I later found out that the dash lights do not work, neither does the map light, and the dome light? My question is what could be the possible problem of this cause. How could I fix it? Any help would be appreciated!
Thank you
Londers27 is offline
Old 01-20-2013, 11:55 AM
frank-id
frank-id's Avatar
Check all the fuses.. Check the owner's manual for the fuses and their values. This should not be a difficult fix. Frank
frank-id is offline
Old 05-24-2013, 12:56 PM
bl817
bl817's Avatar
ditto on checking fuses. dash lights are turned on by the headlight switch and dimmer switch, dome/map light is turned on via door/hatch triggers. could be simple as a bad ground or plug come undone. good luck
bl817 is offline
CS2007
06-25-2019 09:45 PM
ChampInSD
10-02-2015 04:55 AM
LiquidDrink
09-29-2015 10:06 AM
mrappe
09-26-2015 10:16 AM
TfcCDR
09-14-2015 12:08 PM
Quick Reply: Electrical problems. PLEASE HELP!
