Electrical problems. PLEASE HELP!
Yesterday I bought a 1988 2.3 mustang. I later found out that the dash lights do not work, neither does the map light, and the dome light? My question is what could be the possible problem of this cause. How could I fix it? Any help would be appreciated!
Thank you
Thank you
ditto on checking fuses. dash lights are turned on by the headlight switch and dimmer switch, dome/map light is turned on via door/hatch triggers. could be simple as a bad ground or plug come undone. good luck
mrappe
09-26-2015 10:16 AM
TfcCDR
09-14-2015 12:08 PM
