4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
Check Engine Light 2.3L
Old 09-01-2006, 12:47 AM
vindog800
vindog800's Avatar
Default RE: Check Engine Light 2.3L
Okay, I was able to get my hands on a Ford Digital Code reader finally to see what could be causing my Check Engine Light to stay on. I’m hoping now that one of you fine members can help me figure out what to do next. Here are the codes.
For the “Key on Engine Off” Self Test, it comes back as 111 which is pass. Not so for Continuous Memory Codes though, I have a number of them.
1.) Code 172, 186, 222, 223, 224. For the “Key On Engine On” test I first receive the “Failure Mode 998 Code” followed by 222 once again. My book mentions DIS "right side ignition Diagnostic Monitor IDM Signal complete loss of “ say what? If anybody out there can explain this to me to and what I need to do it would greatly be appreciated
vindog800 is offline
Old 11-01-2006, 09:31 PM
Nemesis2k4
Nemesis2k4's Avatar
i had a similar prob wit my 2.3 stang come to find out its a bad EGR
Nemesis2k4 is offline
Old 11-01-2006, 10:12 PM
nismotunedgtr
nismotunedgtr's Avatar
Alright, here are your codes.
172 Oxygen sensor not switching - system is or was lean - Single, Right or Rear HO2S - Fuel control
186 Injector pulse width longer than expected or Mass Air Flow (MAF) lower than expected - Fuel control
222 IDM open or high or right coil pack failure - Ignition Systems
223 Dual Plug (DPI), SPOUT or IDM circuit fault - Ignition Systems
224 Failure in ignition coil primary circuit - Ignition Systems
nismotunedgtr is offline
djbigskrilla
09-20-2022 01:04 AM
labudski
08-24-2015 07:23 AM
microgt
08-20-2015 07:12 AM
mweiland
08-13-2015 05:11 PM
drumhedd2005
08-13-2015 09:59 AM
Quick Reply: Check Engine Light 2.3L
