4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
External Wastegate?
Old 12-28-2006, 06:17 PM
nismotunedgtr
nismotunedgtr's Avatar
Default External Wastegate?
Hey, I'm going to be running the stock T3 on a 1986 Turbocoupe motor.
I hope to be running 20Psi or more. The motor is fresh with Sealed Power dished aluminum pistons. I'm going to be running a Ranger roller cam.
Now onto the question.....
I have to replace the internal wastegate and actuator on my turbo. I'm going to be running a manual boost controller. I was thinking of converting to a external wastegate??
Maybe use the hole on the exhaust manifold for the EGR and put a wastegate on that?
Or maybe one of these:
http://cgi.ebay.com/ebaymotors/T3-to...64876676QQrdZ1
Will a internal wastegate do the jod without trouble? Let me know what you guys think.
nismotunedgtr is offline
Old 12-28-2006, 08:24 PM
Jugador
Jugador's Avatar
Default RE: External Wastegate?
that looks pretty neat, but you'd have to check shock tower clearances if you're gonna be moving the turbo over with that. also, you might be limiting premade exhaust options by having that spacer. you also might have problems with the bolts backing out and being a bitch to tighten in car.
it's definately not even close to ideal, but my car actually has the wastegate flange welded onto the top of the turbine housing and it works alright. i definately like being able to adjust the boost with a hex key and if i really want to boost big, by adding some washers into the wastegate to stiffen up the spring even more.
if you've got cash to burn, check out stinger's tube headers, they have wastegate provisions http://www.stinger-performance.com/headerparts.html
Jugador is offline
Old 12-28-2006, 08:34 PM
TBird232ci
TBird232ci's Avatar
Not enough room for the adapter.
Dont waste your time with an external wastegate unless youre going with a custom header. Im running an internal gate and 21psi. Ran 22psi with an internal gate on my old turbo.
TBird232ci is offline
Old 12-29-2006, 02:08 PM
FoxGT
FoxGT's Avatar
From a performance standpoint it's a good idea, but if you're still running the stock exhaust manifold, save your money. If you're going all out then yes, you want to do this for better flow. That adapter looks like a bad idea for what you're wanting.
FoxGT is offline
msavoia23
12
07-07-2018 12:08 PM
2015Ecoboost
09-17-2015 01:48 PM
rksnow1
09-14-2015 08:46 PM
2l8iwn
09-20-2005 01:44 PM
bc_stang
03-26-2005 05:29 AM
Quick Reply: External Wastegate?
