4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
Painted Valve Cover
Old 05-27-2007, 12:43 AM
SKAR
Moderator
SKAR's Avatar
Default Painted Valve Cover
It looks like this
SKAR is offline
Old 05-27-2007, 01:29 AM
Whitecomet25
Whitecomet25's Avatar
Default RE: Painted Valve Cover
Nice i like it
Whitecomet25 is offline
Old 05-27-2007, 01:39 AM
SKAR
Moderator
SKAR's Avatar
Its on and the cars running (good), but since i did it at night in the driveway i didnt want to take pics of it in the dark, neighbors were having a fire in their backyard
SKAR is offline
Old 05-27-2007, 02:01 AM
sleeper_inc
sleeper_inc's Avatar
Here is mine, I painted it silver. But now I'm thinking about a different cooler like a metalic purple
sleeper_inc is offline
Old 05-27-2007, 02:04 AM
SKAR
Moderator
SKAR's Avatar
Yeah I think it makes it look a lot cleaner, mine was a little rusty and really dirty, the paint isnt perfect, but it looks better. What would be kool for aluminum valve covers? What about polishing them with a wire wheel on a drill all 1 direction? would it keep its finish?
SKAR is offline
Old 05-27-2007, 02:08 AM
sleeper_inc
ORIGINAL: SKAR
I tried it, all it did was leave wire marks all over it[&:] But if you took your time and used a buffer at the end it would look great
Old 05-27-2007, 02:10 AM
SKAR
Moderator
SKAR's Avatar
Did you try it on aluminum valve covers or your steel 1? I want to try it in my 302 valve covers, i remember doing my entire sleds body by hand with emory cloth, it looked good. Would the finish hold up to the water and heat?
SKAR is offline
Old 05-27-2007, 02:12 AM
SKAR
Moderator
SKAR's Avatar
Something new I like about 4 cyl mustangs is my ability to stand in the engine bay beside the upper rad hos to work on the car, a lot easier then leaning.
SKAR is offline
Old 05-27-2007, 12:57 PM
sleeper_inc
ORIGINAL: SKAR
It is way easier, and I used the wire wheel on the steel valve cover
Old 05-27-2007, 01:03 PM
SKAR
Moderator
SKAR's Avatar
Yeah wire wheel on steel would rust quick without some maybe high heat clear coat if that exists.
So I went out and got some pictures
SKAR is offline
Quick Reply: Painted Valve Cover
