springs
RE: springs
you can use a spring compressor, or if you don't have one. carefully...CAREFULLY!Do it this way.
1. remove wheel and raise front of car on jackstands.
2. take the stabilizer bar link off the control arm.
3. put a 5 ton hydraulic jack under the lowercontrol arm and jack up (driectly in center)
4. disconnect the ball joint from the spindel
5. (slowly!!!) lower the jack, so the control arm extends downwards. (carefull cause the spring is still there)
6. when the control arm is lowered, slip the spring out.
(i'm not liable if you get hurt tho.) if you take your time, u can do it this way.
RE: springs
The spring in these cars is always compressed even when the lower control arm is all the way down. Just ask the 5.0 guys who do the lowering spring swap. They have issues getting the spring in[&:]
RE: springs
If don't have spring compressor can remove safely by tying rope around spring and body. That way when it pops out it want go all the way not the best . Reverse same way. Done this on MG's before. Try the autoparts people maybe able to rent or borrow tool.
RE: springs
every one thank you for the input
my problem getting them in the old ones were broke and were very easy to remove they just blow up on removal
so slepper your saing use a compresser? i dont like using them and removing the a arm is out of the qustion any other thought
RE: springs
ORIGINAL: sleeper_inc
See if they will fit in there without them being compressed, then slowly jack the lower a-arms up.
I TAKE NO RESPONSABILITY FOR INJURY!!!!!
Thats my step, he takes no credit if you succeed in getting them in.
