Boost
Boost
I've heard some stuff about electric superchargers. Some high end models can produce as much a 6 psi of boost. How do these things work? Do they stay at a constant speed? Or, do they somehow increase as speed is increased? Does anybody know anything about what these things can do?
RE: Boost
whoa my bad... they cut the price... its only $40
For $40 it is worth a try.... they have 120 day warranty.
http://www.turbonator.com/
RE: Boost
ORIGINAL: hellion_79
Try here.
http://www.boosthead.com/home.php
they were dyno tested against turbo/sc & were the most efficient type of supercharger, downside is they only come with low psi units. 6-8psi. I believe he finished a 12psi one recently
RE: Boost
ORIGINAL: FoxGT
those are exactly what i'm talking about when I say the ones that don't work.
Try here.
Try here.
RE: Boost
um.... belt driven?.... that means not electric.... I meant he makes them.
Here's the link to the ELECTRIC ones
http://www.boosthead.com/product.php?id=18
look at the hp gain compared to the boost #.... 5.5psi... 6psi...
Guy is really helpful too. He helped me get started on building turbo projects back in like 2001. ^_^
There are some dyno sheets on there too if you browse around a bit.
ESCâ„¢ 400 yields 96.5 hp max gains at 5.5 max psi on a '96 Dodge Avenger V6 (automatic trans., TKT headers, 3" exhaust, 60mm throttle body).
Max power: 136.3 stock, 232.8 under boost.
Max torque: 168.5 stock, 249.6 under boost.
Tested on Sept. 30th and Nov. 7th, '03 at South Florida Performance, Inc. Blower housing was ported to improve airflow on later tests.
Last month we sent an ESCâ„¢ to Street Concepts Magazine to install on a Ranger 2.5L 4-cyl show vehicle. You won't believe what they got from that truck! On a stock engine with headers, 3" exhaust, ECU modifications, and electric supercharger @ 6 psi, they took the Ranger from 122 stock whp to 223 whp! Afterwards, the batteries were able provide additional runs off the dyno. Street Concepts' technicians were absolutely blown away by those numbers, so look for a feature article on the ESCâ„¢ in the August 2004 issue.
