Go Back   MustangForums.com > Ford Mustang Tech > 4 Cylinder NA and Turbo
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 02-17-2008, 02:13 PM   #1
sleeper_inc
1988 FORD Mustang
sleeper_inc's Avatar
Vehicle: 1988, Mustang, LX
Default Bad gas mileage?
Lots of people seem to be PM'ing, or e-mailing me about bad gas mileage so I'll just tell you what you should do in this one post.
Bad gas mileage?
1. Pull Codes - http://therangerstation.com/tech_library/OBD_I.html
If no codes come up than continue, if codes do pop up, replace.adjust the parts as requested
2. When was the last tune up done?
If it was over 6 months ago, might be time to do it again (plugs, wires, rotor, cap, oil change, and fuel filter)
3. FPR
The FPR (Fuel Pressure Regulator) is over 20 years old on some of these cars, and more likely than not has blown its diaphram, meaning it has to be replaced (to test, pull the vacuum line off and if there is fuel in it, replace)
4. Bad/clogged injectors
The only true way to check the injectors is to have them tesed at a shop, which will cost you a few hundred dollars, so don't do this step unless your sure
5. Bad MAP/BAP
These will more than likely throw a code if they go bad, so replace if they throw a code
6. Bad MAF
These again will throw a code, replace or clean with a stock unit.
7. ECT (engine coolant temp sesnor)
These will throw a code sometimes, but most of the time they will not when cold.
8. o2 sesnor
Tell the computer your a/f ratio at hwy speeds, so replace if your fuel mileage is down on the hwy or if a code is thrown
9. Thermostat
This will keep your engine way/warm it up faster. 180* is stock, but I recomend 190* because you'll get more heat in winter.
10. Breaks dragging
This will cause your wheels to drag, causeing bad fuel mileage. To check lift your car off the ground, put car in nutral and turn the tires by hand. They should spin with some effort, but still sprin.
11. Under inflated tires
Under inflated tires don't spin as easy as properly inflated ones. Causeing less fuel mileage
12. Vacuum leaks
Car should pull 18+ inch pounds of vacuum at idle, if its pulling less you have a leak some where or your timing is off.
13. Timing
Your cars stock timing should be 10* with the spout unpluged
14. Proper Engine oil
10W-30 for summer, 5W-30 for summer
15. Speed
The faster you go, the more fuel you use
Add more if you can think of them please
__________________
1988 Mustang LX
Ex 2.3 N/A car, was a 2.3 turbo, now getting a complete forged & stroked 408W, shooting for a TT setup
1992 GMC Sonoma 4x4
185,000km's|4.3 auto|current DD getting 24mpg
1991 Mazda MX6 DX
299,000 km's (over 186K miles)| TOTALED!
sleeper_inc is offline   Reply With Quote
Old 02-17-2008, 05:10 PM   #2
MustangGuy93
Default RE: Bad gas mileage?
Also: replace, clean air filter
MustangGuy93 is offline   Reply With Quote
Old 02-17-2008, 06:29 PM   #3
924banger
1992 Ford Mustang
Change Fuel Filter.
__________________
Red 92 LX mustang 4cyl
1992 Bronco 5.8L
2003 Cavalier 2.2L Ecotec
1993 Lightning #1579...Died 12/21/06
924banger is offline   Reply With Quote
Old 02-17-2008, 07:16 PM   #4
bacon57
driving habits, if you drive it hard it gets worse gas milage, and use overdrive
__________________
1990 Mustang LX Hatchback 5 speed- 1 WHEEL PEEL COUNTY CHAMPION 2008
Sometimes dads project: 96 Mustang GT- 4 valve Lincoln motor swap, shift kit. Looks like a girls car, sounds very angry
bacon57 is offline   Reply With Quote
Old 02-17-2008, 08:00 PM   #5
mg man 75
1989 Ford Mustang
Vehicle: 1989 Mustang LX
Change rearend gear ratio to get into stay under 2700 to 3000rpm. That is what mine took.
__________________
89 mustang 86 2.3turbo motor c-4 trans http://www.fquick.com/89-2.3turbo http://s177.photobucket.com/albums/w...20converiable/
mg man 75 is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
