How To: Repin your harness - Page 2 - MustangForums.com
4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
Old 04-23-2008, 08:37 PM   #11
sleeper_inc
sleeper_inc's Avatar
Default RE: How To: Repin your harness
If your using a la, lb, 8ua series computer yes. If a p series... more
sleeper_inc is offline   Reply With Quote
Old 04-23-2008, 09:01 PM   #12
Stang2.3
Stang2.3's Avatar
its a PF3, what else i need??
Stang2.3 is offline   Reply With Quote
Old 04-23-2008, 09:05 PM   #13
sleeper_inc
Your lucky I did this for everyone lol
[align=center]Wiring a P series VAM into a 88-90 Mustang
(this is for when your doing a 2.3 turbo swap with a computer other than a LA, LB, 8UA series)
[/align]Splice into/”T’’ connect the VRef (orange/white) to the wire going to pin 26 of the stock harness (also orange/white). (I say splice into/”T” connect the wire running into the engine bay. This is because pin 26 is being used by the TPS, MAP, and EGR.)
Remove Pin Connector #3 from LX wire harness red block (or take one from your harness you salvaged, and put this pin connector and wire into the red block of your LX harness to plug into your Pin 43 position on the P series computer. The LX harness lacks this connecting pin).
Connect the VAF (white/black) to the wire going to pin 43 of the stock harness (the new connecting pin you just put in)
Connect the VAT (vain air temp) to pin connector #27 (this can be found at your EGR Valve position sensor) Now move that pin #27 to pin #25 and move #25 to an area with no pin (this is the ACT sensor which only the PE, and 87-88 turbo coupe computers can use)
Splice into/"T" connect the VAM signal return (black/white) wire into the LX harness (black/white) wire that goes to pin 46. Do not cut the LX harness (black/white) wire going into pin 46, simply connect this VAM signal return black/white wire to it.
Old 04-23-2008, 09:07 PM   #14
Stang2.3
Stang2.3's Avatar
ya i've got that copy'd and i did that. makes 4 wires... or am i readin wrong?
Old 04-23-2008, 09:19 PM   #15
sleeper_inc
move 4, t into2, and cross fingers and hope it works
Old 04-23-2008, 09:37 PM   #16
Stang2.3
Stang2.3's Avatar
okay then its done..... just gotta hook everything up and tryin and turn her over
and find my vam.....
Old 01-14-2012, 01:33 PM   #17
23 bears
Default help
is this the same for a 93 mustang cuz im puting in a 88 tc motor
23 bears is offline   Reply With Quote
Old 01-27-2012, 07:54 PM   #18
mg man 75
93 is differant. This is site for the 93 notice Sleepers is for 88-90.
I read your closed thread. If you didn't find the info.
1st Read this site and reread many have messed up on it.
http://www.stinger-performance.com/turboswap.html
It is not difficult just read and reread. Most problems occur with "T" wires. This means you take a wire and splice into it another wire. You wind up with 3 wires connected. NOT 2 wires together and a loose one. Good luck. Maurice
mg man 75 is offline   Reply With Quote
Old 11-23-2014, 10:42 AM   #19
shotnva777
Default ???
This makes ZERO sense to me???
All I see is 4 wires. The black one is connected (T'd into) a wire in the harness and the rest of the wires do what???
It doesn't show where to connect on either end of the 3 wires?! Am I missing something???
shotnva777 is offline   Reply With Quote
My idea of Best Bang for Your Buck Car. What do you guys think? mungodrums 5.0L GT S550 Tech 7 10-07-2015 04:01 AM
Starting a new project....could use some input. Matt's 95 Stang 5.0L (1979-1995) Mustang 2 10-05-2015 07:16 AM
04 Mach 460 system, Installed Aftermarket HU, No Highs/Tweeters breaking Audio/Visual Electronics 5 10-02-2015 01:27 PM
Help! Metra 70-5521 AMP Harness Install cbird1177711 2005-2014 Mustangs 2 09-03-2015 08:43 PM
Best Place To Run Power Wire/Firewall '08 cbird1177711 2005-2014 Mustangs 3 09-02-2015 08:51 PM
23, body, computer, cut, fox, harness, pin, repin, repinning, repintool, sn95, turbo, wire, wires, wiring
