and it might also sound stupid... but check ur tranny fluid... if u have no fluid, then there is no way to build pressure to allow gear changes to take place
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
I'll kick your sorry arses so hard you'll kiss the moons.
Well.. I took a look today, and it had a pin in it. However, I did notice that it was an adjustable modulator, so I screwed the adjustment screw out as far as it would go without being pulled out. Now it shifts a little lower, but still way, way too high.
Is there any way that I can adjust the shift points even lower? Perhaps a different sized pin in the modulator?
why would u want it to shift so lowly for? you wouldn't even be in your torque band.. sounds like it would wear the torque converter out... it would have to be slipping its ass off to keep the car moving... and not stalling
__________________
