I went to replace my transmission modulator for my A4LD, (Holy cow a lot of fluid poured out of that vacuum line.
It seemed to hate me... The bolt was difficult to reach, and when it came time to take my old modulator off, it wouldn't.
I pried, I wiggled, I blasted it with PB blaster, I tried EVERYTHING I could think of, and all that happened was it ripped in half. Now I have a busted modulator half stuck in there. I've given up trying to get it out, as I broke more than one tool in the attempt.
My question is. Is it drivable? Will all my tranny fluid pour out of that hole, or will it just leak out slow enough that I can make it to a nearby garage that can pull the other half out and put the new one in?
Please tell me I don't have to call a tow truck, or risk major mechanical problems...
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
Well... I took it to the shop, and they put the new one in.
Now I've got an even bigger problem.
It won't upshift. The only way I can get through the gears is using the select shift to go from 1-2-D-OD. I put it in either D or OD and it just stays in first...
Make sure they out it in right, and make sure all the vacuum lines to the transmission are hooked up
check your kickdown cable also... similar thing happened in my mark vii.. except the calble came off and would immediatley shift to over drive at 20 mph and wouldn't downshift...
your kickdown is probably stuck pulled out
__________________
I'll kick your sorry arses so hard you'll kiss the moons.
