Thanks for the link! That has some great information and some good answers. Hmmm....I wonder how hard a watts link would be to install...ah, I better take this one step at a time. lol
Quote:
An oversteering tendency will be reduced by locating the anti-roll bar at the front where it will reduce the cornering force and adhesion of the front tires. If the vehicle understeers, the anti-roll bar should be located at the rear. If an anti-roll bar is already required at both ends of the vehicle to achieve adequate roll stiffness, use an anti-roll bar of greater stiffness/diameter at the end of the vehicle where reduced cornering force is desired, and use a less-stiff/smaller-diameter bar at the other end.
So here are my thoughts on this... since the Mustang supposedly naturally understeers from factory, when I added the rear sway bar I increased oversteer. Now that I am installing a larger front sway bar, then I will be decreasing the oversteer I just created with the rear, and thus should almost be back to where I started with the understeer, does that sound logical?
Quote:
How hard was the kit to install? Any complications or drilling required?
So far the kit has been relatively easy to install, mainly because I have only installed one component. LOL The k-member brace simply bolts into place, no modification required and boy what a difference it makes in handling.
The strut tower brace does require drilling into the firewall and the strut towers, for this reason I have been putting it off for the fear of drilling into the car.
Also the front part of the brace goes right over the hole you put the oil in so it makes it a bit more inconvenient to add oil. Probably not a big deal, just take some time getting used to it. I will definitely continue holding off on installing it until I get my turbo swap done, I don't know if it will still fit once the reveresed 180 intake is installed.
I haven't installed the sub-frame connectors yet either. I am trying to get some surface rust cleaned up that is around the area where the connectors will go, mainly just because it will be more difficult to work on once they are installed. Can't wait until it starts warming up so I can finish that up. I think the biggest problem with this is that I am having a hard time finding someone to install them for me. No one around here wants to "get involved in that kind of project" so lame, I wish I knew how to weld. LOL
I would definitely suggest you look into one, I can hardly wait to get everything installed. Here is a link to where I got mine. They were the cheapest that I could find and were pretty good to work with.
http://www.mustangsplus.com/xcart/pr...at=3105&page=1
You might want to verify that this kit will work on your convertible though.
