4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
Spray
Old 06-16-2008, 09:00 PM
al_ngl
al_ngl's Avatar
Default RE: Spray
It also raises your compression ratio due to the density of the water in the charge obviously water is denser than gasoline or methanol. I heard that you can even gain 1-2 in your compression ratio, so like 9.5-10.5 compression ratio. That is why I thought that it would give more horsepower than 10.
al_ngl is offline
Old 06-17-2008, 01:16 PM
93light
93light's Avatar
Default RE: Spray
what kinda shot could you put on a n/a 2.3 about a 50 shot right?
93light is offline
Old 06-18-2008, 10:12 PM
mopman93
mopman93's Avatar
Default RE: Spray
i kno somebody who put a 175 shot on a 2.3 never blew it up. i wouldnt go more than a 75 WET shot. on a 2.3 turbo i kno its good for sum serious hp cuz u can crank the crap outta the boost with the meth injection, i'd put at least 40hp if you cranked the boost and all to like 23-25lbs on a stock un ported head. cuz u gotta figure its cooling the intake liek an intercooler plus jacking the compression and adding octane. i mean thats money right there
mopman93 is offline
guitarman376
10-11-2015 01:47 AM
pimp2303
09-17-2015 08:45 PM
5.0 kevo
09-03-2015 06:24 PM
mtxplod
08-29-2015 01:43 AM
dochawk
08-25-2015 08:25 AM
Quick Reply: Spray
