Go Back   MustangForums.com > Ford Mustang Tech > 4 Cylinder NA and Turbo
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-16-2008, 05:48 PM   #1
hillbilly pony
1987 Ford Mustang
Default Advise on a 2.3t Swap
I have a core TC motor that i want to rebuild to basically stock and use in a DD. THe first couple of questions are will a stock 7.5 and A4LD be able to handle a stock 2.3t. If so what are the max limitations for them. I am after all like everyone else and during a rebuild there are always a few "extras" that find there way into a build.
Thanks
__________________
1987 GT. 13.7:1 408 with TW "R" heads, Probe SRS Flat Tops, custom pro systems 950 carb. .671/671 comp cam. Rollerized C4 w/brake 4800 stall, Strange 31 splines w/spool. 10 point cage, Subframes, 4Cyl springs and 90/10's, 50/50's and lakewood uppers/lowers. 325/50/15's
hillbilly pony is offline   Reply With Quote
Old 08-16-2008, 06:56 PM   #2
Boost Gobbler
Boost Gobbler's Avatar
if its your daily id imagin the 7.5 will be fine, my last 2.3 was pretty much my daily and i had a 7.5, i had it about a year and didnt have any problems with the rear. i also had a 3" exhaust, stinger style exhaust manifold, and a front mount with increased boost. as for the tranny. i dont know. i dont think you will have to many issues but i dotn really know. i hear many good things about c4's though :-D, look into those.
__________________
I stole it from grandma..
best time on the slip so far, 13.2 at 106 soon to rise. check out my gotstang page for more info.
Boost Gobbler is offline   Reply With Quote
Old 08-16-2008, 08:35 PM   #3
mg man 75
1989 Ford Mustang
Vehicle: 1989 Mustang LX
7.5 fine. Running c-4 excellant use a Ford Motorsport driveshaft. It is the correct length. If still have the 373 gears change them. Go to 327 or higher. Used as a DD with a c-4 bad gas mileage like 180 miles per tank. I know.
__________________
89 mustang 86 2.3turbo motor c-4 trans http://www.fquick.com/89-2.3turbo http://s177.photobucket.com/albums/w...20converiable/
mg man 75 is offline   Reply With Quote
Old 08-17-2008, 06:45 PM   #4
Richter888
What kind of car are you swapping it into? If its another stang, you will need the t-coupe wiring harness. The factory harness on a n/a motor could work with repinning the ecu plug which isnt hard to do, but you will neede the vam harness to wire in and The computer will be required as well. I lost my t-bird when it caught fire and i swapped the motor into the 89 mustang i have now. When i bought the wiring harness from another guy, he didnt include the injector harness that has oil pressure and water temp sensor for the dash as well. This part was hard to find. I bought mine new from a company i cant remember right now.
The factory open 7.5 would be ok, but the four banger has rear 2.73 ratio, so it will be doggy ass slow lol. I rev mine up to 5000rpm all the time and dump it lol! I converted mine to a manual as well. About that aluminum driveshaft, it will not fit if you use the A4LD. Output shafts are different. I highly suggest doing a maual swap. The driveshaft between the AOD(E) and t-5 are identical. Look up manual swaps, its not that costly and theres plenty of info to get it done.
Ill be honest, the A4LD sucks a big one. The ones from the t-coupes are build a little better but they are still very weak. I dont suggest it.
One more thing, WHY JUST STOCK?! The factory motor can take 17psi daily as it is(mine does lol!). Why not make it better? GOOD LUCK! If ya have any questions just message me. I log on about once a week though.
Richter888 is offline   Reply With Quote
Old 08-18-2008, 01:59 PM   #5
sleeper_inc
1988 FORD Mustang
sleeper_inc's Avatar
Vehicle: 1988, Mustang, LX
You have some good things, but most are WAY OFF!
The 7.5 will hold till around 300hp, so your good there. The A4LD will not last long if you beat on it. Mine lasted 1000km's before I lost 3rd and 4th (around 90k miles on the transmission)
You'll need to build the A4LD to the 4.0 explorer standard to take the power without failing.
Remember, Keep It Simple Stupid
__________________
1988 Mustang LX
Ex 2.3 N/A car, was a 2.3 turbo, now getting a complete forged & stroked 408W, shooting for a TT setup
1992 GMC Sonoma 4x4
185,000km's|4.3 auto|current DD getting 24mpg
1991 Mazda MX6 DX
299,000 km's (over 186K miles)| TOTALED!
sleeper_inc is offline   Reply With Quote
Old 08-18-2008, 03:01 PM   #6
hillbilly pony
1987 Ford Mustang
will and explorer a4ld bolt-up??
__________________
Old 08-18-2008, 06:12 PM   #7
sleeper_inc
1988 FORD Mustang
No, it has a different bell housing.
You'll have to swap most of the internals into the 2.3 A4LD.
Search "A4LD transmission rebuild" on google, it should be on explorer forums
__________________
1988 Mustang LX
1992 GMC Sonoma 4x4
1991 Mazda MX6 DX
Old 08-19-2008, 05:37 PM   #8
924banger
1992 Ford Mustang
couldn't you get the SBF adapter plate from Stinger and hook the explorer A4LD right up?
__________________
Red 92 LX mustang 4cyl
1992 Bronco 5.8L
2003 Cavalier 2.2L Ecotec
1993 Lightning #1579...Died 12/21/06
924banger is offline   Reply With Quote
Old 08-19-2008, 08:00 PM   #9
sleeper_inc
1988 FORD Mustang
The 4.0 is a V6, not a SBF bolt pattern...
__________________
1988 Mustang LX
1992 GMC Sonoma 4x4
1991 Mazda MX6 DX
a4ld, output, shafts
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
