4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
4cyl question
Old 08-25-2008, 03:30 PM
USMCrebel
Mach I Section Moderator
USMCrebel's Avatar
Default 4cyl question
i bought a 1985 merkur with the 2.3t and i've got a classic with a 5.0 in it, and i was wondering if they use the same mounts on the frame as the 5.0?
USMCrebel is offline
Old 08-25-2008, 03:38 PM
sleeper_inc
sleeper_inc's Avatar
No, the 5.0 is different than the merkur, merkur is different than the turbo coupe, the turbo coupe is not the same as the mustang 2.3
sleeper_inc is offline
Old 08-25-2008, 03:41 PM
USMCrebel
USMCrebel's Avatar
im not worried about the motor mounts, are the frame mounts different, and could i get a part umber or something...im almost ready to swap in the 2.3 t into the classic...just ironing out some details
Old 08-25-2008, 03:47 PM
USMCrebel
USMCrebel's Avatar
lemme ask another way,
lets say i had a 5.0 85 mustang and i wanted to swap a 2.3l in could i slap some 2.3 motor mounts in place of the 5.0 motor mounts and the engine fit?
Old 08-25-2008, 03:52 PM
sleeper_inc
Yes, the merkur is mounted with a stud and nut, the mustang is a bolt and nut.
Swap the 2.3T with a diff. computer and injectors (VAM?) then swap the 5.0 into the merkur
Old 08-25-2008, 07:53 PM
USMCrebel
USMCrebel's Avatar
actually the merkur might be getting a 393 stroker
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: 4cyl question
