4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
heads?
Old 08-26-2008, 02:43 AM
88stang5.0GT
88stang5.0GT's Avatar
Default heads?
are the 8 spark plug heads a direct replacement for 4 spark plug heads on my 89? and about how hard are they to find?
88stang5.0GT is offline
Old 08-26-2008, 09:25 AM
ExtrmZ
ExtrmZ's Avatar
The head you are looking for shouldn't really be that hard to find, i am thinking that it should just bolt on to your single-spark block... but i am not totally sure, they had thoose heads in rangers, and mustangs too.. 91+ in the mustangs and i am thinking about the same with the rangers
ExtrmZ is offline
Old 08-26-2008, 10:02 AM
sleeper_inc
sleeper_inc's Avatar
the 8 plug head will bolt right on, but then you have the issue of firing the other 4 plugs... Just put a 4 plug head back on.
4 plug head - 74? to 90
8 plug head - 91-93, 89-95 (ranger)
sleeper_inc is offline
Old 08-26-2008, 12:29 PM
88stang5.0GT
i already have a 4 plug head but the 8 plug head gave the 2.3's 20 or 30 horsepower more so i thought if i could just bolt it on with no problem it would be a quick way to get a little more acceleration because i almost cant handle how slow it is right now
Old 08-26-2008, 12:35 PM
ExtrmZ
ExtrmZ's Avatar
its actually the cam in the head, not really the dual spark..
ExtrmZ is offline
Old 08-26-2008, 12:38 PM
88stang5.0GT
oh i read somewhere that when they added that head they ported it more than the other ones and i assumed thats why the 91+ had more horsepower than my 89
Old 08-26-2008, 01:42 PM
ExtrmZ
ExtrmZ's Avatar
those heads run a roller sytle camshaft and followers, they one you have in your 89 is a flat tappet style followers, they are less effecient, but still work.. when ford started putting the rollers in their cars, they put out a little more hp..
ExtrmZ is offline
Old 08-26-2008, 02:24 PM
924banger
924banger's Avatar
Port your 4plug head and go grab the roller setup off the year models Sleeper listed. You'll come out with more hp than the 8pluggers and you won't have to go through the headache and money to fire the extra 4plugs.
924banger is offline
Old 08-26-2008, 02:52 PM
ExtrmZ
ExtrmZ's Avatar
that would be the way to go, i did that, but i stuck with an aftermarket flat tappet cam from comp cams..
ExtrmZ is offline
Old 08-26-2008, 02:53 PM
88stang5.0GT
if i wanted to do roller everything what all would i need to change? just the cam and rockers?
Quick Reply: heads?
