Go Back   MustangForums.com > Ford Mustang Tech > 4 Cylinder NA and Turbo
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-28-2008, 10:12 AM   #11
93FoxbodyLX
93FoxbodyLX's Avatar
Vehicle: 1993 Mustang LX
thanks guy for helping me out with all this, so what would be a wise decision right now? ditch the cut springs and jus buy lowering springs?
__________________
93' Foxbody LX, 2.3, AT, Accel Wires, Accel Plugs, Lowered 2.5"/1.5"
93FoxbodyLX is offline   Reply With Quote
Old 09-28-2008, 11:12 AM   #12
al_ngl
1993 Ford Mustang
Vehicle: 1993 Mustang LX 2.3
Send a message via Yahoo to al_ngl
I'd go with lowering springs myself. Sounds kinda shoddy just cutting them up. Hey, where in Indiana are you located? Haven't seen anyone else from IN in the 4 cyl section.
__________________
"The battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol, but the clock is correct!"- James May
al_ngl is offline   Reply With Quote
Old 09-28-2008, 12:17 PM   #13
Stang2.3
1985 Ford Mustang
Stang2.3's Avatar
Vehicle: 1985 Mustang SVO
[quote=FoxGT;5490661]Cutting your springs raises spring rate & makes the front stiffer, but you can go too far with it. Heating up the springs to lower ride height will lower spring rate making the car likely to bottom out.[quote]
I'm a litte Confused by that? i could have been wrong on "spring rates" but how would Taking a Portion of the spring make it Stiffer?, unless the coils were re-coiled.
__________________
Jake Bastian
1985 Ford Mustang SVO
"If Work Was So Great, the Wealthy Would Keep It For Themselves"
Stang2.3 is offline   Reply With Quote
Old 09-28-2008, 11:13 PM   #14
alboy91lx
1984 Ford Mustang
My Garage
alboy91lx's Avatar
Vehicle: 1991 Mustang
id just go and buy some springs... i got the eibach and there great... not super rough and it lowered it very evenly...
__________________
"half assed equals half as fast"
84 Ford SVO
K&N Cone Filter
Aeromotive fuel pressure reg
Adjustible Boost Control
Stinger Performance 3 inch turbo back
17 psi of boost
and stupid flat top pistons!!! (bought car this way)
alboy91lx is offline   Reply With Quote
Old 09-29-2008, 12:14 AM   #15
93FoxbodyLX
Quote:
hey man i live in west lafayette
__________________
Old 09-29-2008, 12:16 AM   #16
93FoxbodyLX
Quote:
unless i can score some used ones im not gonna buy them new since they r kinda pricey, im also tryin to go for a raked dropped too, thats why i dropped the front 2.5" and the rear 1.5"...but for now im gonna keep the springs until i get some more money later
__________________
Old 09-29-2008, 12:20 AM   #17
al_ngl
1993 Ford Mustang
Cool I used to live in Lafayette near Greenbush Street on the north. Still have family out that direction. Now I'm down west of Indy.
__________________
Old 09-29-2008, 12:40 AM   #18
alboy91lx
1984 Ford Mustang
My Garage
alboy91lx's Avatar
http://cgi.ebay.com/ebaymotors/79-87...spagenameZWDVW
Lots of cheap springs on ebay...
__________________
84 Ford SVO
K&N Cone Filter
17 psi of boost
Old 09-29-2008, 03:39 AM   #19
93FoxbodyLX
o ya i love shoppin Ebay lol, i get most of my parts from there if i cant get them anywhere else cheap
__________________
Old 09-29-2008, 12:18 PM   #20
FoxGT
Vehicle: unicycle
Send a message via AIM to FoxGT
Quote:
You could either find a used spring, cut it halfway down & try pushing it down after you've cut it.
It might not be very noticable on a smaller scale like just taking an inch off. Think about it like this, lets say you could have a spring wrapped with the same amount of coils/ft same coil thickness, but have the spring 10 feet tall. If you jumped on the spring it would have alot of give in it & wouldn't push you back up very well. Now compare that with a car spring that has the same amount of coils/ft with the same coil thickness. You jump on it it won't go down much & it will have alot harder of a push to it.
The coil/ft & thickness is staying the same, but there is less spring so it gets stiffer the more you cut. If you were to heat it up to lower it, then the coil/ft would increase while thickness would remain making it have alot more give to it.
Looking at how springs work: (http://home.earthlink.net/~bazillion/design.html)
Quote:
Based on these general principles, you now know what to do to change the properties of a spring you already have. For instance, if you want to make automotive valve springs a little stronger than stock, you can a) go to a slightly heavier wire and keep the dimensions and coil count the same, b) decrease the diameter of the spring, keeping the wire size and coil count the same, or c) decrease the number of active coils, keeping the wire size and spring diameter the same. Naturally, you can also go to a stronger material to achieve the same result.
What he did to his springs was the same described in (c)
__________________
If you have to ask what it takes to get to 500 HP, you don't have what it takes to get there.
'89 Mustang GT
'86 Mustang vert
'84 TT 351w notch
'89 Turbo Ranger
'96 Musta
FoxGT is offline   Reply With Quote
14, 50, causing, cut, cutting, height, increasing, lower, mustang, mustangs, problems, quality, rate, ride, roush, springs
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
