compression test results
#22
sleeper took the words right out of my mouth. haha
yeah, the video shows the vacuum gauge at idle. the knocking sound, to me at least, is very faint and the only time i can hear it is at idle when the hood is up. there's no noticeable blowby, so i don't think it's an issue with rings. i was thinking about pulling the head and doing a valve job, but the machine shop suggested not doing that unless i work on the block also. i think the first step is swapping the vacuum hoses out for silicone to see if that's what's causing the issue. i may do that in the next week or so. i've also been told to put a quart of ATF in the crankcase and that will clean up the lifters if they are dirty.
#23
Well, it's not jerky/rapid so that pretty much rules out a stuck valve or collapsed lifter. Stuck valves/bad lifter usually will be rapid and pronounced, like a windshield wiper. I can't really hear the knock, but then again, my wife says I can't hear her either! (There is a reason for that) ANYWAY, it looks like you just might have a worn out seats in the head. An air leak shouldn't cause surging vacuum readings. It has to be something changing the direction of air flow. Just an outside shot here, but have you checked the one way valve/check valve on the brake booster? Might be worth a shot. Forgive me here, but I can't remember if you stated whether you had good oil pressure or not(?). A low idle knock can be worn rod bearings.
#24
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
GT350 S550 Tech
09-29-2015 03:29 PM
