Go Back   MustangForums.com > Ford Mustang Tech > 4 Cylinder NA and Turbo
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-18-2008, 04:20 PM   #1
jpogioli
Vehicle: 1989 Ford Mustang
Default manually shifting an automatic
I know I will probably get flamed for asking this, but is it bad to manually shift my automatic transmission. I have done nothing with shift kits or anything like that. Does anyone do this? I have done some general research on-line and there is about a 50/50 split between "it will destroy your transmission" and "it is not bad at all." Thank you.
__________________
1989 Mustang LX 2.3L Convertible
ram air intake
various restoration pieces
Near Future:
5.0 Mustang, hopefully nice GT
jpogioli is offline   Reply With Quote
Old 11-18-2008, 06:36 PM   #2
sleeper_inc
1988 FORD Mustang
sleeper_inc's Avatar
Vehicle: 1988, Mustang, LX
I did it on my A4LD.... It then proceeded to spill it's guts.
It's fine to do if your not beating on it (shifting at 3500+ RPM)
__________________
1988 Mustang LX
Ex 2.3 N/A car, was a 2.3 turbo, now getting a complete forged & stroked 408W, shooting for a TT setup
1992 GMC Sonoma 4x4
185,000km's|4.3 auto|current DD getting 24mpg
1991 Mazda MX6 DX
299,000 km's (over 186K miles)| TOTALED!
sleeper_inc is offline   Reply With Quote
Old 11-19-2008, 12:06 AM   #3
killer91
1970 Ford F-100
My Garage
Vehicle: 1984 mustang gt turbo
Send a message via AIM to killer91
if its stock probably not the best idea my freinds super coupes tranny blew after he did that a couple of times but after he had it completly redone it was fine (full throttle shiftin at 5500....)
__________________
1970 ford f100 and 1984 mustang gt turbo, and 84 mustang gt!
rust- cheap/lazy mans weight remover
killer91 is offline   Reply With Quote
Old 11-20-2008, 08:16 PM   #4
FoxGT
Vehicle: unicycle
Send a message via AIM to FoxGT
I can't speak for the a4ld, I have never taken one apart nor know anything about them internally. The Aod is the same way as far as half of the people say it will kill it, half say it wont.
With the aod, the big problem is when the overdrive band is engaged. You DON'T want the band to engage during a shift. It'll cause it to wear out very fast & damage the transmission. It's ok for it to engage either before or after a shift, not during.
The problem with it is most people shift it wrong. What they call the 1-D-1 shift which is used to shift to 2nd & make it hold 2nd until you manually put it back into D. Most people shift from 1 to D then very quickly back down to 1 again which causes the OD band to engage during the shift. The correct way is to accelerate in 1st, when you want to shift to 2nd you move it to D then wait for it to get into 2nd. After it has completed the shift you move the shifter back down into 1.
Again, i'm not sure if ford built the a4ld the same way or not. It's something worth looking into. Shift kits & manual valve bodies are easy to install imo.
__________________
If you have to ask what it takes to get to 500 HP, you don't have what it takes to get there.
'89 Mustang GT
'86 Mustang vert
'84 TT 351w notch
'89 Turbo Ranger
'96 Musta
FoxGT is offline   Reply With Quote
Old 11-21-2008, 12:20 AM   #5
JayRolla
Vehicle: 1993 Eagle Talon TSi Turbo
Whats the actual difference. Why would it cause more load on the tranny unless your revving too high, which the rev limiter should stop you from doing anyways. My buddy did it all the time in his Z28 3rd gen camaro.
JayRolla is offline   Reply With Quote
Old 11-21-2008, 08:45 AM   #6
sleeper_inc
1988 FORD Mustang
Transmission isn't meant to be shifted hard at a high RPM, plus the A4LD isn't known for it's strength.
The more load on the trans = more heat, which means less life, which means huge rebuild costs
__________________
1988 Mustang LX
1992 GMC Sonoma 4x4
1991 Mazda MX6 DX
Old 11-21-2008, 02:37 PM   #7
TRBOPWR
Vehicle: 1985 SVOx2, 1986 SVO
Why would you want to shift an auto yourself? Sounds like just the possibility of more wear for very little to no gain.
__________________
Sig courtesy of Tombohum
1985 SVO 13.62 @ ~97mph with 1.74 60' and 20 psi, on the brakes trying to keep from breaking out!
TRBOPWR is offline   Reply With Quote
Old 11-23-2008, 01:34 AM   #8
FoxGT
Vehicle: unicycle
Quote:
Can't speak for the a4ld. The purpose on the aod was to hold the gear longer, without manually shifting it would shift as it's starting to get into the powerband.
On mine I had to because I had a manual valve body & not doing so would cause lots of heat because of the stall. Then I swapped to T5 due to lack of overdrive on the c4.
__________________
'89 Mustang GT
'86 Mustang vert
'84 TT 351w notch
'89 Turbo Ranger
'96 Musta
Old 11-26-2008, 11:42 AM   #9
jpogioli
pretty much just for poops and giggles. i really enjoy driving standard but due to the wife not being able to drive one, both cars are automatic.... hopefully that will change in the near future though
__________________
ram air intake
Near Future:
Old 12-09-2008, 05:01 PM   #10
Stang2.3
1985 Ford Mustang
Stang2.3's Avatar
Vehicle: 1985 Mustang SVO
Quote:
Originally Posted by jpogioli View Post
...i really enjoy driving standard but due to the wife not being able to drive one, both cars are automatic...
Just do what i did. Teach her, or have Your Car and Her Car.
After i taught my wife, She Loves Drivin Standard, and her Truck is Standard
__________________
Jake Bastian
1985 Ford Mustang SVO
"If Work Was So Great, the Wealthy Would Keep It For Themselves"
Stang2.3 is offline   Reply With Quote
08, 1988, 1989, 23, 89, a4ld, automatic, ford, kit, lx, manually, mustang, shift, shifting, trans, transmission
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
