Go Back   MustangForums.com > Ford Mustang Tech > 4 Cylinder NA and Turbo
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 01-21-2009, 06:15 PM   #1
selbystang
Vehicle: 1989 mustang coupe
Default intercooler options for 2.3t
i have a 89 coupe and a 87 tc i am going to do the swap but wanted to get a few things done while i am at it. First i was looking into the intercooler. I have heard of people using the volvo ic but didnt know if this would be a temporary fix or if this would get me to my goal of low 13 high 12 1/4 mile times.i dont want the ones that are very noticable either.
selbystang is offline   Reply With Quote
Old 01-21-2009, 06:41 PM   #2
evintho
evintho's Avatar
Vehicle: Turbocharged 1989 Mustang convertible
The Volvo unit will work but it has plastic end tanks that tend to blow off under moderate boost. It also has quite a bit of pressure drop and small inlets/outlets. Guys have used the smaller Mitsubishi Starion I/C's, '87-'88 TC I/C's mounted in front and some of the cheap I/C's off Ebay. My research has led me to the large Isuzu NPR I/C. It's the best bang for the buck without going into an aftermarket I/C, such as Spearco. The NPR is all metal, has very little pressure drop and 2-3/4" inlets/outlets.
Fits like a glove in my '89 ragtop. Sorry, I don't have a pic with the nose on but believe me when I say, with the car assembled you absolutely can't see it!
__________________
Trust in the Lord with all your heart and lean not on your own understanding.
Proverbs 3:5
1989 Mustang convertible w/built and turbo'd 2.3.
evintho is offline   Reply With Quote
Old 01-21-2009, 06:57 PM   #3
TRBOPWR
Vehicle: 1985 SVOx2, 1986 SVO
The above choice is a popular one for sure. I am just running an ebay knockoff myself, but you can see it through the hole in the bottom of the bumper. I think it mostly comes down to how much you want to spend and how much fabrication work that you want to do.
__________________
Sig courtesy of Tombohum
1985 SVO 13.62 @ ~97mph with 1.74 60' and 20 psi, on the brakes trying to keep from breaking out!
TRBOPWR is offline   Reply With Quote
Old 01-21-2009, 07:04 PM   #4
selbystang
where and how much for the npr it looks like what i would want, but would it be able to handle the power needed to run low 13 1/4 mile. thanks
Old 01-21-2009, 07:47 PM   #5
sleeper_inc
1988 FORD Mustang
sleeper_inc's Avatar
Vehicle: 1988, Mustang, LX
Buy a 7.3 power stroke intercooler. Cut 7 rows off it, weld it and you have an intercooler that will never need to be upgraded again for $300?
I'm going this route when I find a dang holset
__________________
1988 Mustang LX
Ex 2.3 N/A car, was a 2.3 turbo, now getting a complete forged & stroked 408W, shooting for a TT setup
1992 GMC Sonoma 4x4
185,000km's|4.3 auto|current DD getting 24mpg
1991 Mazda MX6 DX
299,000 km's (over 186K miles)| TOTALED!
sleeper_inc is offline   Reply With Quote
Old 01-21-2009, 07:59 PM   #6
TRBOPWR
Quote:
Start roving your local pick 'n pulls, you may get lucky. They tend to be fairly cheap in the grand scheme of things. And it's more than enough to run a low 13. How you are getting more power is more important in that aspect of things...
__________________
Old 01-21-2009, 08:21 PM   #7
selbystang
i plan on upgrading to a bigger turbo. i am going to up the fuel system while doing the swap also i have a 255 lph walboro i need to figure out what injectors to go with.i am also going to do the clutch while i am at it. i have another ? how could i tell that the engine i have has upgrades. the guy told me it has some head work a cam and bigger turbo and for the fuel control it has a rapido equalizer it looks like a equalizer for a radio but i think it said superchip on it
Old 01-21-2009, 08:34 PM   #8
TRBOPWR
Head and cam work you won't really be able to tell unless you pull the head off and check things out. There should be a series of numbers on the turbo that show the size, I believe the stock turbos on 87 TC's had AirResearch or something on them, they are the smaller IHI's. A popular upgrade was to swap to the T3.
Your car is not going to like injectors any bigger than it already has, the LA3 can't really control anything bigger without some sort of piggyback system. The 35's are about all you can get. Do you want low 13's in street trim? Or in an all out drag setup type of car?
__________________
Old 01-21-2009, 08:34 PM   #9
sleeper_inc
1988 FORD Mustang
Cam - have bigger lift/lobes
Head work - ports will be smooth
turbo - What engine is it?
__________________
1988 Mustang LX
1992 GMC Sonoma 4x4
1991 Mazda MX6 DX
Old 01-21-2009, 08:42 PM   #10
selbystang
i would like it in street form basically i probably wont hit the track much but i want to have something that if i want it to get up and go it will.i say the low 13 range because i have been in a few mustangs that run those times and that is the feeling i am looking for.they are all v-8 but i have looked on a few websites and have seen people running those times with the 2.3t. i just wanted to build something different.i am used to my bike that i have been riding for almost a year straight everyday and there isnt many cars on the road that can touch that thing. it runs 9.7 in the 1/4
23, 23t, ford, forum, ii, intercooler, intercoolers, j3, moates, modified, mustang, options, powerstroke, safc, svo, times, turbo
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
