Mine is leaking really bad and i cant find them at any autozone/napa and ford doesnt make them anymore. Am i going to have to go to a junkyard and hope i can find one that works?
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
i just ended up buying the ford racing proportioning valve, but i cant get the old one off. do you have any idea if im supposed to use a special tool or of a website that will walk me through it
Did you get a Combination Valve or just a Proportioning Valve? The proportioning valve is mainly used for all wheel disc brakes, where as the combination valve is for front disc and rear drum setups (combination valves have a metering valve too as one unit).
Either way, i would use PB blast on the ends of the brake lines by the valve and make sure your using flare wrench to take the lines off.
A flare wrench is a wrench that stops you from rounding off the fittings via using a regular wrench. There cheap and are available at all good autoparts stores.
