Go Back   MustangForums.com > Ford Mustang Tech > 4 Cylinder NA and Turbo
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 06-13-2009, 03:03 PM   #51
Babybudistmonk
1993 Ford Mustang
Babybudistmonk's Avatar
Vehicle: 1993, Ford, Mustang
alright, ill have to look around a little bit. Now one more question, if I find a 60/48 T3 thats complete, could I put the 60/63 turbine wheel in place of the 48 w/o any major modifications? Or are the housings different?
And what is NATO? Havent heard of them, well, as far as cars go anyways :-)
__________________
1993 Ford Mustang LX
2.3NA Auto Tranny
Cold Air Intake
Pacesetter Exhaust
Convertible
Currently collecting parts for 2.3T and 5 Speed swap.
1979 Ford Mustang LX Ghia
Currently in the works...
351 Windsor
D&D Motorsports Tubular K-Member, A-Arms, Upper and Lower Controll Arms
8.8 Rear End
Babybudistmonk is offline   Reply With Quote
Old 06-13-2009, 09:25 PM   #52
Babybudistmonk
1993 Ford Mustang
Just got this on ebay! the only one i could find that has the actuator and the waste gate. The exhaust elbow isnt pictured but he said it was included. Me = :-D
__________________
2.3NA Auto Tranny
Cold Air Intake
Pacesetter Exhaust
Convertible
351 Windsor
8.8 Rear End
Old 06-14-2009, 12:56 AM   #53
evintho
evintho's Avatar
Vehicle: Turbocharged 1989 Mustang convertible
Cool
Not sure if the housings are different, or not. However, to swap turbine wheels you'd need to dismantle the entire turbo. I'd just stick with whatever you come up with. NATO = North American TurboCoupe Organization - www.turbotbird.com
So, you found a complete T3! 60/63 or 60/48?
__________________
Trust in the Lord with all your heart and lean not on your own understanding.
Proverbs 3:5
1989 Mustang convertible w/built and turbo'd 2.3.
evintho is offline   Reply With Quote
Old 06-14-2009, 09:37 AM   #54
sleeper_inc
1988 FORD Mustang
sleeper_inc's Avatar
Vehicle: 1988, Mustang, LX
Thats a .60..48 by looking at the compressor housing and the T off the compressor housing but it maybe a .60/.63?
__________________
1988 Mustang LX
Ex 2.3 N/A car, was a 2.3 turbo, now getting a complete forged & stroked 408W, shooting for a TT setup
1992 GMC Sonoma 4x4
185,000km's|4.3 auto|current DD getting 24mpg
1991 Mazda MX6 DX
299,000 km's (over 186K miles)| TOTALED!
sleeper_inc is offline   Reply With Quote
Old 06-14-2009, 12:28 PM   #55
Babybudistmonk
1993 Ford Mustang
Well it came out of a merkur xr4ti, so I'm guessing it's the 60/48. I would rather have the 60/63, but this would be a better place to start than the stock IHI that's on the tc. Also, the turbo supposedly only has 60,000 miles on it too.
And after searching through all the military stuff when I googled NATO, i did find the turbo coupe site. Wow that does look like a good recourse for info about those cars.
__________________
2.3NA Auto Tranny
Cold Air Intake
Pacesetter Exhaust
Convertible
351 Windsor
8.8 Rear End
Old 07-02-2009, 06:07 PM   #56
Babybudistmonk
1993 Ford Mustang
so, i got my turbo and am thinking of using the stock intercooler that came on the tc. will it pass enough air for the t3 to work properly, or is it pretty restrictive?
__________________
2.3NA Auto Tranny
Cold Air Intake
Pacesetter Exhaust
Convertible
351 Windsor
8.8 Rear End
Old 07-03-2009, 01:31 AM   #57
evintho
evintho's Avatar
Cool
The factory I/C is small but actually flows quite well. On thing though, don't mount it on top of the turbo like the factory does. That totally defeats the purpose. It's basically just a big heat sink mounted there! Mount it out front, behind the grill, in the air stream to take full advantage of it.
__________________
Proverbs 3:5
Old 07-03-2009, 12:05 PM   #58
Babybudistmonk
1993 Ford Mustang
i was thinking of making a ram air hod that would work similar to how the tc did, but with a more direct flow. How does that sound?
__________________
2.3NA Auto Tranny
Cold Air Intake
Pacesetter Exhaust
Convertible
351 Windsor
8.8 Rear End
Old 07-03-2009, 01:26 PM   #59
evintho
evintho's Avatar
Cool
Ford, in all their infinite wisdom, tend to make bad design decisions from time to time. Distibutor mounted TFI's, exploding Pinto and Explorer gas tanks, etc. Add the turbo mounted I/C to the list! The TC ram air effect helps. Some have even mounted small electric fans to the underside of the I/C. However, the I/C is mounted directly over the hottest part of the engine combined with the fact that it is in an enclosed space. Most of the function of the I/C (cooling the air charge) is lost due to the surrounding heat generated by the very hot engine in the confined engine compartment. The I/C is MUCH more efficient if mounted in front of the grille where it can pick up cool (70*) inrushing air as opposed to sucking in hot engine compartment (180*) air. Very few of the turbo guys mount it in the stock location on a swap. Most convert it to a FMIC, and for good reason!
__________________
Proverbs 3:5
Old 07-03-2009, 01:36 PM   #60
mustang2.3
mustang2.3's Avatar
Vehicle: 1993,ford,mustang lx
Send a message via Yahoo to mustang2.3
hey evintho were did you get that top pipe that beds 90* off of your turbo?
mustang2.3 is offline   Reply With Quote
1979, 23, 23t, 351, e6, ford, harness, head, hoses, motor, ported, pull, turbo, vacuum, winsor, wiring
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
