Hoping somone can help me verify my diagnosis of a faulty fuel pump.
When I first got the mustang there was a slightly high pitch ringing sound comming from the right hand back side of my car, I suspect above the gas tank on the right hand passenger side.
I assumed it was a fault with the fuel pump I payed no attention at the time... the engine seems to run great but the other day it died at an intersection twice. I am guessing the fuel pump was the cause, sometimes while idleing the engine shudders for a while and the muffler bangs agains the underbody for a little while then the fan gets louder and it seems to run a little smoother for a few minutes and the cycle repeats, I guessed this was a fuel pump issue and was planning to pick one up tonight after work.
so I was going to pick up a fuel pump tonight, any heads up would be greatly appreciated!
Kalen.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
Check to make sure the inertia switch isn't tripped or partially tripped (back of hatch/trunk area there is a hole with a switch, push the button down.)
Also make sure the pump is getting full power to it from the relay
__________________
1988 Mustang LX
Ex 2.3 N/A car, was a 2.3 turbo, now getting a complete forged & stroked 408W, shooting for a TT setup
1992 GMC Sonoma 4x4
185,000km's|4.3 auto|current DD getting 24mpg
1991 Mazda MX6 DX
299,000 km's (over 186K miles)| TOTALED!
my pump was also noisey,The car quit a few times, fuel pump not running.I changed the pump. I still had the problem.It turned out being the relay.Its located under the hood on the passenger side strut tower.I bought a used one on ebay for five bucks , problem solved!
do you know of a way to tell whether the relay is faulty or not? could you smell fuel in the car? i can smell fuel in the car sometimes while the car is in idle, this leads me to believe it is a pump issue.
I thought my fuel pump was going, there was a squealing sound coming from what seemed like the back passenger side, turned out it was my driveshaft rubbing on my exhaust.
__________________
1991 Ford Probe GL 2.2 5spd - bit rusty, bit smokeya t start, goes great, only 162,000 km
1990 Ford Tempo 2.3 5spd ---- 323,500 km and still going strong NOT just blew the clutch Oct. 30
1993 Mustang 2.3 N/A auto 229,000 ---- For sale, $1000 obo
I had no fuel smell.It just would not start some times.I then jiggled the relay and the pump came on.So I replaced it , and no problems since.Sounds to me like you may have a fuel leak some where.
no fuel leaks, replaced pump and filter, there was a pinched relief line, probably the cause of the ringing sound. problem solved now i just have to figure out the major loss in power hehe.
