I always used regular in my car, never had any problems. The way it started running about a month ago, it seemed as if there wasn't enough air going into the engine, it sounded almost like it was choking. The more gas you gave while driving, the lower the rpms would dip. Very weird indeed. Then one day, the local Shell was out of reguler, so they were selling premium for the same price. Filled up and BAM problem gone. Next time I filled up with regular, no problems. A couple more tanks, and the same problem. Went to a different gas station, filled up with premium, and problem gone! What the hell could the problem be with my car? I'm sick of buying premium gas, since I go through like 4 tanks a week for work. Help!
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
1991 Ford Probe GL 2.2 5spd - bit rusty, bit smokeya t start, goes great, only 162,000 km
1990 Ford Tempo 2.3 5spd ---- 323,500 km and still going strong NOT just blew the clutch Oct. 30
1993 Mustang 2.3 N/A auto 229,000 ---- For sale, $1000 obo
Guessing... Carbon buildup has raised the compression. Ping detector is backing the engine off.
You have done all the other obvious things. Filters, sparks, injectors, ect I assume.
__________________
2008 manual GT with deluxe trim, FRPP CAI, FRPP GTB Mufflers & 91 Tillman Tune. 3.73 gears, Coast Ultralight Drive-shaft. 18" OEM Polished Bullitts, Webelectric Sequentials, XM built into the Shaker 500. Alarm and Escort 8500.
I would think that you could clean the piston tops and such without rebuilding. I don't know this, I am only guessing because I had a 2 stroke bike I used to have to scrape carbon from it frequently. If the valve train is also dirty you would have to look into that, too. I would think even with cleaning carbon from the pistons, there would still be some carbon in the ring grooves. Just what I think.
__________________
"The battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol, but the clock is correct!"- James May
