Go Back   MustangForums.com > Ford Mustang Tech > 4 Cylinder NA and Turbo
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-01-2009, 02:39 AM   #1
Juggalo351
1993 Ford Mustang
Vehicle: 1993 Ford Mustang LX
Default need to improve my mpg
ok i drive a 93 lx, 2.3 5 speed. problem is ive never gotten any good mpg on it, what should i replace or do to improve it? already taken the air silencer out and did a tuneup, getting my front end fixed and aligned soon so that should help a bit. anyone got any ideas? dont need 40 lol, but 22-30 would be better than what it is now. thanx for any help guys
Juggalo351 is offline   Reply With Quote
Old 09-01-2009, 11:39 AM   #2
silverscmustang
silverscmustang's Avatar
Vehicle: Awaiting next Ford :)
make sure tire pressure is correct and clean/change your air filter if you havent already
__________________
Previous Cars:
2005 Mustang V6
2005 Mustang GT
New car coming soon
silverscmustang is offline   Reply With Quote
Old 09-02-2009, 04:15 PM   #3
ExtrmZ
check the stickies at the top of the page. sleeper did a huge write-up on improving mpgs.
very good tips
__________________
"88 LX Hatchback 2.3L
ExtrmZ is offline   Reply With Quote
Old 09-03-2009, 01:43 PM   #4
humboldt707
Vehicle: 1993,ford,mustang
Unhappy
i got the same problem on my 93 2.3l,,, its gets ****ly gas mileage i need sum help 2
humboldt707 is offline   Reply With Quote
Old 09-04-2009, 07:59 PM   #5
dreamer1uk
Vehicle: 1993 Mustang Convertible 2.3 N/A
Send a message via Yahoo to dreamer1uk
Hey
What did you purchase for the Tune up? Did you replace the PCV, O2 sensor, fuel filter and such?
__________________
1993 2.3 Mustang Convertible
dreamer1uk is offline   Reply With Quote
Old 09-04-2009, 11:08 PM   #6
Juggalo351
1993 Ford Mustang
plugs wires air filter and oil change. so o2 sensor, fuel filter, and the pcv. about the pcv, the ones at the store have a double fitting, and i know mines wrong. question is where does that second line go?
Old 09-05-2009, 01:38 AM   #7
dreamer1uk
Hi,
The bottom of the PCV valve connects to the bigger vacuum hose that heads to the block. For the other two vacuum lines, one heads to the upper intake manifold and the last vacuum hose runs along the firewall to a t-fitting that heads to the vacuum ball in the passenger side fender area.
Hopefully this makes sense.
__________________
Old 09-05-2009, 06:56 PM   #8
Juggalo351
1993 Ford Mustang
ok well mine is def wrong then. guess whoever did it before was an idiot. its got a vacuum line with a little plastic elbow in it that runs only to the intake. oh this comes from the top of the valve cover, ill try to get a pic in a bit
Old 09-10-2009, 10:13 AM   #9
toplessLx
Vehicle: 1992 mustang lx
yeh my pcv is the same way. no valve just to lines with an elbow. now im a general mechanic and i knew that looked wierd but i figured it couldve been somethin ford did so i aint bothered it
toplessLx is offline   Reply With Quote
Old 09-10-2009, 03:57 PM   #10
Juggalo351
1993 Ford Mustang
figured it out a bit, the pcv is behind the intake under the egr. replaced that and noticed it hadnt been connected to the big line running from the block, seems like it fixed my idle lol. as for the hose on top, dunno exactly what its for but im cleaning it up a bit with just a solid hose, mine seems a bit loose like it would cause a vacuum leak
1993, 23, 23l, 50, 93, carburated, gallon, gas, improve, improving, mileage, miles, mpg, mustang, pcv, system, vacuum
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
