Go Back   MustangForums.com > Ford Mustang Tech > 4 Cylinder NA and Turbo
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-11-2009, 01:19 AM   #1
Albert88LX
Vehicle: 88 LX, 93 GT
Default Cluster Accessories Issue
When I try to start my 88 LX up, none of the cluster lights come on and I'm unable to crank the engine. I'm wondering if I've got a ground problem or if there is a another fuse hidden somewhere other than the panel on the driver's side.
I recently put a new front bumper, headlights, and front left fender apron on. Also ,the hazard lights and turn signals are not working but the headlights do work. It was running until I did the body work.
Thanks for any help you can give.
Albert88LX is offline   Reply With Quote
Old 09-11-2009, 07:49 PM   #2
mg man 75
1989 Ford Mustang
Vehicle: 1989 Mustang LX
Welcome to the forum. I hope this helps. And since new if If explain too simple sorry. The cluster lights, fuel , oil etc. on the lower right of dash pod. It is only used on the GT from what I read. I have them on mine but mine is hodge pod of parts so that is explainable. Or are talking about the dash lights? Now on the start problem. Sounds like a ground wire off. Is the starter solinoid mounted must be to work. Start looking for any black wires not mounted to body. That is usually a ground wire. Hope this helps. If unsure on some wiring where they go. Mine is a same and I can look and see if would help. Maurice
__________________
89 mustang 86 2.3turbo motor c-4 trans http://www.fquick.com/89-2.3turbo http://s177.photobucket.com/albums/w...20converiable/
mg man 75 is offline   Reply With Quote
Old 09-12-2009, 02:24 AM   #3
Albert88LX
To clarify my problem, when I try to start the car the instrument panel doesn't light up at all. The warning lights should flash for a second when the car starts but I'm getting nothing. That's what leading me to think it's some kind of electrical problem. I'm just hoping that somebody might have had this problem before and could give me some pointers to troubleshoot it.
Thanks Maurice for the ground issue idea. I'm going to check everything tomorrow. I'll let you know if it works.
Old 09-12-2009, 03:45 PM   #4
dreamer1uk
Vehicle: 1993 Mustang Convertible 2.3 N/A
Send a message via Yahoo to dreamer1uk
Hey,
Does the starter motor crank over the engine at all when you turn the key to the start position? Or do you have a no crank condition?
__________________
1993 2.3 Mustang Convertible
dreamer1uk is offline   Reply With Quote
Old 09-14-2009, 02:22 PM   #5
sleeper_inc
1988 FORD Mustang
sleeper_inc's Avatar
Vehicle: 1988, Mustang, LX
Clean all your connections to the battery and the starter solenoid. If you get a click when you turn the key and nothing happened's you have a bad connection
__________________
1988 Mustang LX
Ex 2.3 N/A car, was a 2.3 turbo, now getting a complete forged & stroked 408W, shooting for a TT setup
1992 GMC Sonoma 4x4
185,000km's|4.3 auto|current DD getting 24mpg
1991 Mazda MX6 DX
299,000 km's (over 186K miles)| TOTALED!
sleeper_inc is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
