Go Back   MustangForums.com > Ford Mustang Tech > 4 Cylinder NA and Turbo
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-16-2009, 09:44 AM   #1
WyldeSoul
Default Help with an odd noise
Just recently my car developed a bit of an odd noise, that I'm wondering if I should worry about.
When I'm turning a gentle to moderate left at speeds above 15 or so, I get an odd, high frequency noise from the rear.
Sounds almost like a grinding, but it's quiet, and so high frequency that it sounds more like a brake chirper than any grinding you'd describe as grinding. It doesn't exclusively happen when braking, but it doesn't go away when you do, either.
Any ideas?
__________________
Good morning is an oxymoron.
WyldeSoul is offline   Reply With Quote
Old 09-17-2009, 01:46 AM   #2
dreamer1uk
Vehicle: 1993 Mustang Convertible 2.3 N/A
Send a message via Yahoo to dreamer1uk
Hi,
If you think its coming from the rear, id start by taking off the Drums and check for Shoe wear as well as checking the hardware. Id also check for seal leaks too from the axles.
Hope this helps.
__________________
1993 2.3 Mustang Convertible
dreamer1uk is offline   Reply With Quote
Old 09-18-2009, 02:50 AM   #3
milanorama
1993 Ford Mustang
milanorama's Avatar
Vehicle: 1993 Mustang LX
Check your exhaust, it might be rubbing on your driveshaft very lightly. You'll be able to tell if there's a clean stripe on a part of the driveshaft.
__________________
1991 Ford Probe GL 2.2 5spd - bit rusty, bit smokeya t start, goes great, only 162,000 km
1990 Ford Tempo 2.3 5spd ---- 323,500 km and still going strong NOT just blew the clutch Oct. 30
1993 Mustang 2.3 N/A auto 229,000 ---- For sale, $1000 obo
milanorama is offline   Reply With Quote
brake, chirper
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
