I don't believe anybody on here has done it, and I don't think anybody anywhere has done it smoothly. More than enough power can be made on the regular head, I think most have been moving toward the opinion that the swap is more of a pain to accomplish than it is worth in the end.
Don't let my downer opinion dissuade you though if it's what you want to do. turboford.net is probably the best place you could look for info. At least a few people have accomplished it over there.
__________________
Sig courtesy of Tombohum
1985 SVO 13.62 @ ~97mph with 1.74 60' and 20 psi, on the brakes trying to keep from breaking out!
a buddy of mine knows a guy who did it. the volvo head, stock internals, t3-t4 hybrid with 12 lbs of boost in a 79 pinto runs low 10's. if thats not power or smooth work then what is?
Smoothly, as in it was a simple swap. Unless you are extremely confident in your abilities to modify what needs to be modified and then in turn tune it yourself to make it run like a raped ape then go for it. I am simply saying that it is more complicated than alot of stuff you see on the internet makes it out to be, and that you can make good power with the regular old eight valve head.
__________________
The way i see it, i want something that not alot of people have. And nobody an my town, or state for that matter has done this swap. I can get the head for cheap, turbo's are easy to get ahold of, and i have the tools and things to do it.
I am on there by same name. Several e-mails are banned. Way I understand those do a lot of spamming. So he banned them. Unsure what is allowed. Mine is gmail over there but I joined when it was allowed. Can try contacting them from this page. http://www.turboford.net/index.shtml
You can still use search on the forum. It is open to everone. One warning if thinking of joining. Use the search, use the search, use the search. If you post a question that search would answer you will get flamed by many. Good people and very well knowledgeable. But they don't like to answer the same question over and over. Just the way they are. Maurice
