I have narrowed down everything to my computer being bad. My advance curve is opposite (retard curve) and all of the sensors and wires are in good shape and reading right. Is there a way to reflash my stock computer? Would i be best off by buying a stock replacement from NAPA or OReily's? Should i find one from a smashed car in a JY?
My motor is Cammed and bored. The motor ran fine when we put it back in the car, and has slowly lost its niceness. Now the only way it'll run is when the SPOUT is unhooked.
Any Suggestions?
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
Either j-yard or swap out with autoparts. I don't think noone reflashs the NA computer and not many do the turbo ones. PS what is the code on the computer. Remember mine use to be a na. Not sure if save my old one or not. Maurice
I have a reman computer i got from bumper to bumper I just pulled out of my 1990 na auto. in case you need one . and if it will work for you ---I am putting a carb set-up on mine.
If mg-man can't find his ,,contact me i'll sell cheap. It's going on E-BAY shortly.
Only thing that comes to my mine is the pip or tfi on or in the distributor. I assume you checked belt timing. http://rothfam.com/svo/reference/sensors.pdf page 17 how to test using meter. Also how to test all the other sensors.
what are the symptoms of the car? when it comes to the distributor i would only use motorcraft parts. I had tried an msd cap on my dist. and it would misfire at 10lbs.
__________________
"Saying, 'I'm going to take my ball and go home' will be of no help, as we are well stocked in balls and don't need your wussy pink ball cluttering up the place anyway."
