4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
idle fluctuates between 800-700...2.3L,when warm
Old 07-22-2010, 12:41 AM
roscoo
roscoo's Avatar
update:
well finally got the car running great...turned out to be a bad EGR sensor (not to be confused with egr valve)....idle surge is gone...and milage is way better...even trans seems better,as before it would sometime double kick down on excel (must have been getting to much gas?)...
much thanks all :-)
roscoo is offline
Old 07-22-2010, 06:05 AM
Babybudistmonk
Babybudistmonk's Avatar
Glad to hear you got her figured out!
Babybudistmonk is offline
Old 07-26-2010, 01:12 AM
roscoo
roscoo's Avatar
Babybudistmonk:
thanks again for all the help....
after last post,i noticed surge came back again...errr
so i re went over this thread,and relized i had done everything you said,but had left out cleaning IAC....so today i took it off (what a horrible place...bottom screw was a bitch to get to)...i had some seafoum left over (basically same type stuff as carb cleaner),so gave it a good cleaning with that and some qtips (to help get extra crap out of two ports,and pin thing)...let it dryed off for 10 min or so,and reput back togeather...and!!! wow...it's like a whole new car...i cant believe it...it purrs like a kitten now...
recap:
check engine light was on and codes showed oxyen sensor,egr sensor (both replaced)...cleaned throttle body,cleaned mass air flow sensor...and finally today cleaned IAC.....can enjoy driving it :-)
roscoo is offline
4cylinderplus2
10-09-2020 07:45 PM
TCStangerv6
10-11-2015 05:57 PM
svfetter
10-05-2015 11:39 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: idle fluctuates between 800-700...2.3L,when warm
