4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
Which was does Dist. turn on 85 2.3t?
Old 11-26-2011, 04:44 PM
Svtwv
Svtwv's Avatar
Default Which was does Dist. turn on 85 2.3t?
Im getting my motor ready to go back in tom..and Im gettin ready to prime my engine. Which way does the distributor turn in these motors? I have seen clockwise on google but nothing with solid info. Thanks
Svtwv is offline
Old 11-27-2011, 05:22 PM
mg man 75
mg man 75's Avatar
I think so. You know can use 5/16 socket to drive pump. Make sure to tape the socket to extension. A battery drill does best. Try one way if no pressure reverse drill. I assume you did not go with hi flow/ hi pressure pump. Bad idea. Hard on distributor gear and center of distributor shaft. Maurice
mg man 75 is offline
lincolnshibuya
12-08-2015 04:37 PM
breaking
10-02-2015 01:27 PM
ChampInSD
10-02-2015 04:55 AM
09-30-2015 12:39 PM
logan409
09-26-2015 07:43 PM
Quick Reply: Which was does Dist. turn on 85 2.3t?
