4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
Lost what little power I had
Old 04-06-2012, 07:57 AM
PNYXPRESS
PNYXPRESS's Avatar
Default Lost what little power I had
Last night the starter selenoid on my 1991 2.3L shorted out and was giving constant power to the starter even with the ignition turned off. I replaced the selenoid and everything seemed fine afterwards. This morning the car has very little power and wont rev above 3K while driving. It also stalls out while driving and then tries to stall when I release the clutch to start going unless I rev it up to 2500 and ride the clutch until its rolling enough to sustain 2000 rpms.
What could have been fried from the selenoid shorting out? Where do I start looking.
PNYXPRESS is offline
Old 04-07-2012, 12:25 PM
PNYXPRESS
PNYXPRESS's Avatar
Found the problem, the timing belt was apparently loose on the gears and it advanced to about 40* timing. adjusted it back and tightened the tensioner pulley and everything is running great now
Old 04-07-2012, 09:29 PM
mg man 75
mg man 75's Avatar
Great news. One warning if you replace it with the autoparts 4 wire version. Go to Ford or j-yard and get a FORD one. The 4 wire one's are junk. I went thru 3 from differant suppliers all failed again. A used Ford one solved my problem. I got a new one in trunk just in case. Maurice
mg man 75 is offline
jrrhd73must
10-02-2015 09:17 PM
KingRando
10-02-2015 08:06 AM
ChampInSD
10-02-2015 04:55 AM
09-25-2015 06:58 PM
Quick Reply: Lost what little power I had
