No Fire on Center Cylinders
I am looking at a 1992 LX with a dual plug 4cyl. The owner said it drove fine and then just started running very bad. He started the engine for me and ran it for a few minutes. By touching the exhaust manifold I found out the center two cylinders are not firing. Could this be a simple fix? Injectors,coil packs, sensor, or ??????
I have not been able to hook up a code reader yet.
Thanks for any insight.
Lot later giving you some info. I found this may tell you how to test system. Maurice
http://easyautodiagnostics.com/ford/...ule_test_1.php
Also, try swapping in an ignition control module, I picked one up for my old mustang for $35 at the local junkyard. I had the same problem and was dumbfounded, I had done coil packs, plugs and wires. The ICU solved it though, good luck with yours.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
