92' need help on codes 62, 95, and 66!!
Ok so these are the codes I got and what they pertain too.
62 - Torque Converter Clutch Error (C,M), AXOD 4/3 Or 3/2 Pressure Switch Circuit Grounded (O)
95 - Fuel Pump Circuit Open-PCM To Motor Ground (CM,O)
66 - , MAF signal below minimum test voltage of .4vdc (O,CM,R), Transmission Fluid Temperature Circuit Grounded (CM,O)
So here is the thing... Rumor had it it was gonna cost me 75$ to get a mechanic to read my codes, but thanks to this site I found a simple alternative by just using a conductor. I noted my codes and then dialed a mechanic which informed me they would still have to read the codes and charge me to go from there. Excuse me but screw that. The problem with my car is that when I slow down or go to turn its idle starts bouncing and then dies on me. It's more so got worse since its gotten hotter outside. I replaced the mass air flow sensor already. My question is the meaning. I need to know exactly how I need to go about this without getting an outrageous shop bill. I've dropped a lot of money into this pony and I don't plan on stopping bc she's a dern "good'en!" If anyone can give me advice, even if a little I'd appreciate it greatly. So far this site has helped me with all my problems and now more than ever I need this car to run. Please do not fail me now! If yu have any questions pertaining to the issue, feel free to ask. Thank yu!
if your car is a 92 then it will have 3 digit codes. rescan and post results when you can. also you can try cleaning/replacing idle air control valve. check and set your throttle position sensor. check/replace power steering pressure sender. those are some of the basics. good luck
lincolnshibuya
12-08-2015 04:37 PM
