4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
Trouble Shifting
Old 08-24-2013, 07:36 PM
Greg Rouse
Greg Rouse's Avatar
Default Trouble Shifting
Is this a common problem with factory parts in Foxbody models? I currently drive a '93 LX and I haven't had any work or maintenance performed on the transmission since I've purchased it off a private owner a year and a half ago. Sometimes, I have to shut the car off in order to shift into first after stopping. And other times I nearly force it into gear especially when downshifting.
I only ask this because I had a '92 5.0 once before and had similar problems with it. When I finally got our mechanic to look at it he cried. So much metal shavings inside the works. I had to replace my flywheel and a lot else. Now I have a 'new' car and I'm experiencing the same problem. I plan on upgrading and purchasing a new transmission (hopefully the T5), but I just don't know how much more 'life' I have on the current parts.
It worries me when I'm in traffic and every so often I gotta finagle engaging the gears. I swear I'm just making it worse.
Greg Rouse is offline
CS2007
06-25-2019 09:45 PM
Thunderball
15
11-22-2015 11:49 PM
chrisdbassplayer
10-13-2015 06:53 PM
Explosive
10-02-2015 07:45 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: Trouble Shifting
